Help Quick- Fuel Injector Broke?
Old Apr 27, 2005 | 05:25 PM
blaze309's Avatar
I decided to pull off my fuel rail to see if any of my fuel injectors are leaking, the back left injectors were hard to pull out and when i got it out the #8 injector didng have a o-ring on it but i found it in the hole. I think it's broke though becuase the little plastic piece that's above the injector oring (white plastic piece) is broke. It's split in half. So do i need a new injector?
Old Apr 27, 2005 | 05:57 PM
BMAN'S SCZ's Avatar
Re: Help Quick- Fuel Injector Broke?
I would think you would be alright because the o-ring seals it up and the rails hold it in place. As long as it didn't crack any further than just the flange for the o-ring seat.I have some 24# Ford SVO's for sale if you are interested though. Good Luck.......John
Old Apr 27, 2005 | 06:11 PM
madwolf's Avatar
You will be OK. I've used injectors without that white plastic piece and they work fine. Just make sure to lube the o-rings with a little bit of oil before putting them back in or you'll have a hard time pushing them in and possibly damage them. You definetely don't need a new injector though.
AdsoYo
May 2, 2018 03:21 AM
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
