Mototron 60lb. per hour High Impedence fuel injectors... any good?
Old Aug 27, 2004 | 06:03 PM
donot_4get's Avatar
Mototron 60lb. per hour High Impedence fuel injectors... are they any good? I'm looking for the biggest high Impedence injector that I could find...
Would I be better of with 50# DELPHI Injectors??
leo
Old Aug 27, 2004 | 06:09 PM
simple's Avatar
Re: Mototron 60lb. per hour High Impedence fuel injectors... any good?
dont they have a high imp. 85# now?
from what i've seen, they are relatively new and not too many use them
might want to search www.hardcore50.com (or any Mustang board) and some of the Turbo Buick websites
Old Aug 27, 2004 | 09:50 PM
donot_4get's Avatar
thanks I'll go and check
leo
Old Aug 27, 2004 | 10:06 PM
mike85gn's Avatar
The turbo Buick guys love 'em! I run them in my GN and they're fantastic, great idle, more fuel than I'll ever use. Some websites list them as 65lb. per hour injectors, but that is rated at 43.5psi. People have run them as high as 85lb. per hour at 60psi, and have had no problems with fueling even on 25+ psi of boost. So the rating is conservative and they scale very linear and support a LOT of power.
Old Aug 27, 2004 | 10:14 PM
donot_4get's Avatar
those are some fantastic news!!!
I'll be buying them!!!
leo
Old Aug 28, 2004 | 06:27 AM
FASTFATBOY's Avatar
These work with a stock PCM?
Old Aug 28, 2004 | 07:57 PM
donot_4get's Avatar
I far as I'm aware of... yes!
leo
Old Aug 28, 2004 | 10:31 PM
kmook's Avatar
Advanced Tech Moderator
They may be good they may not. I've run Low Z Injectors before, but I have no first hand experience with large high Z injectors, so I look at what more experienced people in this field have to say like LJ for example-
http://www.acceleronics.com/faq.htm#1
Old Aug 29, 2004 | 08:10 AM
JT Metal's Avatar
I Had Speed Inc. in Schaumburg put these Motron 60's in two months ago. They seem to run fine. I was leaning out the 42.5's with 8psi of boost. But as far as I can tell they work great, Idle fine, And yes work with the stock computer. Also should support over 650RWHP with the correct fuel system of corse...........joe
Old Aug 29, 2004 | 08:30 AM
donot_4get's Avatar
I just found somethin interesting about them....
"here are some pics of the mototron/siemens deka 60lb injectors that i bought from ********, they are infact siemens deka's but they just have mototron stamped on them:"
you guys can see pics and the whole thread at
here (corral.net)
leo
Old Aug 30, 2004 | 12:17 AM
OneFlyn95z28's Avatar
I am looking at thiese also. Need some thing for the monster and so far everyone seems happy with idle quality. that is where large injectors are weakest BTW
Old Aug 30, 2004 | 12:40 AM
Lisa33's Avatar
I have them, works fine for me. Run them at 50psi fuelpressure and have the constant set at 65lbs, idels perfect.
Feffman
Oct 9, 2015 05:42 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
moneyshotz
Jul 27, 2002 06:16 AM
