Motor won't start.
Old May 7, 2004 | 11:02 PM
Bobs 94 TA's Avatar
Motor won't start.
My TA died on me the other day, and I cannot figure out why. It cranks, but it won't start. It's got fuel and spark.
This sucks.
Old May 7, 2004 | 11:06 PM
OBE1 95Z28's Avatar
Try holding the gas peddle all the way to the floor when cranking; be sure to let of the gas quickly if it starts!
Old May 7, 2004 | 11:09 PM
Bobs 94 TA's Avatar
tried it, still nothing.,
Old May 7, 2004 | 11:15 PM
OBE1 95Z28's Avatar
How did you determine you have good spark? My firend's 96 had a similar problem and we held a spark plug wire up to the block and concluded we had spark. Turns out the spark was weak due to a fauly coil (tested the spark with a spark gap tester). Repaced the coil and problem solved!
Old May 7, 2004 | 11:18 PM
Bobs 94 TA's Avatar
yeah, I did the plug wire to the block thing.
I'll look at the coil tomorrow. Thanks man.
Old May 7, 2004 | 11:21 PM
OBE1 95Z28's Avatar
The spark gap tester was pretty cheap...like $10. If you've got a friend in the area that has a F-Body with the same style coil, a quick swap can confirm the issue. I'd confirm before I bought a new coil as I doubt you can return it if it's not the problem.
eazyZ
Mar 1, 2015 07:12 AM
Scottyboy
Feb 11, 2015 10:28 PM
Cam's maro
Jan 30, 2015 09:21 PM
Jessie4tin
Jan 7, 2015 08:53 AM
