motor pulling?
you can pull the motor and trans out the top pretty easy. i think its better than from the bottom. bout a 4 hour job. they can come out together or apart. apart will make it easier. me and a buddy of mine took an ls1 with tranny out the top with no air tools in his front yard. put it back in and cranked it too so it can be done. be sure to take the radiator and condensor out. take as many parts off the pulley system as you can. its all just common sense really.
What trans? I have seen pictures on here of someone do it with an M6. Mine was pretty snug coming out the top with no trans and no acces. on the front (except the balancer). If its an auto trans., I can't really see it coming out attached.
Originally posted by JDBlaze85
i've seen it. i've done it. it will come out. gotta wrestle it around a bit tho.
Henson071
May 4, 2015 12:23 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
