crate LT1
Old Jun 23, 2004 | 05:47 PM
ARTIC_Z's Avatar
crate LT1
my car has a newer motor if was replaced in 2000. i was told that it could be a corvette lt1 i dont know what the diff is but i was wondering if someone could tell me.
Old Jun 23, 2004 | 05:50 PM
J's 82's Avatar
the only difference was four bolt mains vice two bolt for the f-bodies
in the cars the engine was rated higher in the corvette because of its less restricted intake and exhaust.
Old Jun 23, 2004 | 05:54 PM
Dave89IROC's Avatar
If it was replaced at a dealer or with a engine from the dealer, it should be a 4 bolt
ARTIC_Z's Avatar
thank you. so the f-body and the vette's had the same motor just the diff intake and exhaust.so if its a vette lt1 it can handle more power being a 4 blot main corect?
Old Jun 23, 2004 | 06:02 PM
Dave89IROC's Avatar
with one exception
y-bodys(vettes) got the 4 bolt mains from the factory
f-bodys got the 2 bolt from the factory, but the replacment engine from/through GM was a 4 bolt(everything I've heard points to this)
as for strength
in theory, the 4 bolt is a little stronger, but, they both came with the same internals that ussually fail first, so, you figure it out
one thing about 2 bolts, you can go with aftermarket splayed 4 bolt cap, which are stronger then the stock GM strait 4 bolts
Old Jun 23, 2004 | 07:33 PM
maddog89's Avatar
i have several friends who race dirt track and run 355's solely and they all swear by the four bolt main blocks,,but i've seen 2 bolt main blocks turn out just as much hp and take just as much abuse as a 4 bolt main block,,like the other guy said its usually other parts which give out way before the the main caps,,,,,,,,,,,,,
95chwagon
Feb 28, 2015 12:02 PM
hotrodyou1
Dec 20, 2014 10:05 PM
ModdedNerd
Dec 18, 2014 10:52 PM
nballisru
Dec 14, 2014 05:01 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
