Motor Mounts
Old Feb 17, 2024 | 09:37 AM
weedog's Avatar
Motor Mounts
Ready To Sit Engine Back In 97 Z28 But Want To Replace Motor Mounts What Is a Good Brand To Buy. They Say Westar Is Crap. Thanks
Old Feb 17, 2024 | 11:02 AM
Re: Motor Mounts
What happened to the original motor mounts?
I never had to replace the motor mounts, even after 27 years, most of those years with an 800 HP/800 lb-ft build sitting on them. Only replaced the trans mount with poly, and that lasted for all those years under three different trans setups (T56, TH400, TH400+GV O/D). I'll have to ask the new owner if he has replace the motor mounts since he bought it.
Hint: If you turn your "caps lock" off, the system won't automatically reformat your text into lower case with a cap starting each word.
Old Feb 17, 2024 | 05:34 PM
Chimera96's Avatar
Re: Motor Mounts
I used Energy Suspension black ones. Way easier to replace with engine out of car.
Gtpguy
Jul 25, 2012 12:45 PM
z28 justin
Apr 18, 2011 08:54 AM
wheelliftnpony
Jun 26, 2009 01:50 PM
jeremys 98 ls1
Dec 11, 2006 02:12 AM
LOW TRAC
Jun 30, 2003 07:02 PM
