Motor mounts
Old Nov 15, 2011 | 12:10 PM
undecidedfbody's Avatar
Motor mounts
The time has come for me to put new mounts in my car does anyone know or done mounts. The motor is out of the car and I just got a free brand new pair of energy suspension poly mounts. I just need the details how to do it
Thanks for the help
Old Nov 15, 2011 | 01:43 PM
nintythreeZ28's Avatar
Re: Motor mounts
remove old mounts
install new mounts
install motor
drink beer and do a burnout to test them out
Old Nov 15, 2011 | 02:00 PM
RUDEDOG's Avatar
Re: Motor mounts
Remove old rubber from clamshells by drilling or grinding rivets. install poly (might have to grind a little off for good fit) into clamshells and re-install with bolts.
Old Nov 15, 2011 | 11:04 PM
Re: Motor mounts
Thanks guys for all the help
some burnouts are in order
Old Nov 15, 2011 | 11:44 PM
Rob94hawk's Avatar
Re: Motor mounts
FYI with these poly mounts if your car is cammed you will feel it. Especially in your dashboard.
Old Nov 16, 2011 | 08:31 PM
DrivingZiggy's Avatar
Re: Motor mounts
I've also heard that if your motor mounts are poly, your transmission mount should be also. If one or the other is not the same, it makes for lots of vibration.
Old Nov 17, 2011 | 02:14 AM
Rob94hawk's Avatar
Re: Motor mounts
Hmm. Don't feel any excess vibrations in the Pro 5.0 shifter. I'll have to look into it. thanx
Old Nov 17, 2011 | 07:33 AM
RUDEDOG's Avatar
Re: Motor mounts
Poly trans mounts are mandatory.
Old Nov 17, 2011 | 07:55 PM
CamaroBoy96Z28's Avatar
Re: Motor mounts
Originally Posted by nintythreeZ28
remove old mounts
install new mounts
install motor
I'd say this pretty much sums it up. I've got Prothane motor and trans mounts. My cam is fairly tame so I don't notice much of anything in the way of excess vibes in the cabin.
HectorM52
Jul 30, 2017 11:46 AM
Rde Bandit
Mar 21, 2015 10:17 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
silvermansteve
Mar 4, 2015 05:02 PM
Nostang 96z
Aug 31, 2002 12:01 PM
