Motor mount question...
Old Mar 29, 2005 | 08:28 AM
Myxtreme1's Avatar
Is there a difference from the driver side to the passenger side? I am buying new inserts for the shells and there was a note on Summit's website that it was for driver's side only. Any info will be very appreciated. Thanks!
Old Mar 29, 2005 | 08:59 AM
CamaroBoy96Z28's Avatar
Re: Motor mount question...
I'm in the process of doing prothane poly replacements right now and yes both sides are different. The actual mount (clamshell) mounts to the k-member on the pass side and to the block on the driver's side. Different shape mounts and mounting position.
Old Mar 29, 2005 | 09:16 AM
Myxtreme1's Avatar
The inserts are different?
Old Mar 29, 2005 | 09:20 AM
Yes
Old Mar 29, 2005 | 09:31 AM
Myxtreme1's Avatar
Happen to have a pn for the pass side?
Old Mar 29, 2005 | 12:18 PM
Afraid not, didnt know you could get them separately. I just used Summit p/n PTP-7-508-BL for the pair in black.
Old Mar 29, 2005 | 12:43 PM
FIREHAWK #7's Avatar
how much did you pay for them??? thinking about buying some, just wanted to know how much they went for???
Old Mar 29, 2005 | 04:16 PM
Myxtreme1's Avatar
Thanks! That helps!
Old Mar 29, 2005 | 04:18 PM
Myxtreme1's Avatar
Copy his pn and look it up at www.Summitracing.com
HectorM52
Jul 30, 2017 11:46 AM
Rde Bandit
Mar 21, 2015 10:17 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
silvermansteve
Mar 4, 2015 05:02 PM
Nostang 96z
Aug 31, 2002 12:01 PM
