Most powerful cam?
Old Aug 11, 2006 | 10:23 PM
frankthetank078's Avatar
Most powerful cam?
what is the biggest cam you can put into an engine with stock heads? by biggest i also mean which gives you the biggest gain
Old Aug 12, 2006 | 08:39 AM
OldSStroker's Avatar
Re: Most powerful cam?
**LE1 head/cam setup coming before summer ends along with some other good stuff**
Did you change your mind?
It depends on what you mean by "biggest gain". If you are looking at area under the torque curve (in the rev range you will run the engine) which should give you best acceleration, the optimum cam won't be very "big".
It might be fairly close to what you had in mind in your signature.
Old Aug 12, 2006 | 09:00 AM
Mean Green's Avatar
you can jam a 24X/24X 110 LSA cam in there and it would be big, but stock heads are going to choke it off so bad, you'll never see the power.
With stock heads, I wouldn't really go anything above a 22X/22X duration and a 112LSA at the most. Anything bigger is going to be useless unless you have the airflow from the heads to back it up.
Old Aug 12, 2006 | 03:37 PM
slomarao's Avatar
People have cc306's and gm 847's in motors with stock heads. They usually lay down 340-355 rwhp and similar torque numbers, depending on the trans and the rest of the setup. Those are the biggest cams as far a duration and lift go that I have read about on this site. As mentioned before the stock heads are going to choke the cams i talked about. Get the le1 setup you have in your sig. or get the le1 heads and a le2 cam. The potential for the motor lies the heads. You can only throw in so much cam. good luck
Old Aug 13, 2006 | 01:33 AM
oo ok i thought the heads would cut alot of the power from the cam but what about getting different heads and leaving the same cam.. would that choke it more considering the heads wouldnt be getting the most amount of air and fuel
Old Aug 13, 2006 | 02:46 AM
blackz97's Avatar
That would yield less power then just stuffing one of the cams mentioned (cc306 or gm847) into a stock headed car. Better flowing heads require larger cams to take advantage of their increased flow. There would be gains with the better flowing heads but not significant.
Steve
Old Aug 13, 2006 | 09:54 AM
1racerdude's Avatar
Big heads--smaller cam for the same HP level.
If ya got GOOD heads ya don't need a big stupid cam to make HP, but a stock cam won't get ya there.
Old Aug 13, 2006 | 10:46 AM
Mean Green's Avatar
heads and cams go together as a package. You really can't build power with one and not the other.
Old Aug 13, 2006 | 11:49 AM
OrbitalChris's Avatar
yes you can...get a custom grind, I have stock heads and run 11.4-11.6s and dynoed close to 400rwhp
Old Aug 13, 2006 | 11:55 AM
CamaroRacing12's Avatar
orbital that seems like a sweet setup......hehe one i may copy in the future
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
InfernalVortex
Jan 17, 2015 09:35 AM
XtremeLt1
Sep 13, 2002 08:50 PM
