Most Power Put Down by LT1 Hotcam?
Old Jun 15, 2012 | 11:41 PM
  #31
dizwiz24's Avatar
Re: Most Power Put Down by LT1 Hotcam?
352 rwhp / 355 rwtq w/ long tubes (1.75"), 6spd manual,alvin^pcmforless tune
Btw this was on 93 lt1 corvette w/ no cats. Big shot dyno (dynojet) tallmadge, oh
Old Jun 16, 2012 | 07:01 AM
  #32
96capricemgr's Avatar
Originally Posted by williepgee
A4 with stock stall. I have my shift points tuned at 6200 rpms. I let it shift itself. 1-2 about 35. 2-3 about 68
Stock stall is a BIG problem, you should have done a good stall converter first. I say this as someone else who also did a cam first and gained basically nothing till I gave it proper supporting mods.
Old Jun 16, 2012 | 07:20 AM
  #33
williepgee's Avatar
What size stall do I need. 2500?
Old Jun 16, 2012 | 08:10 AM
  #34
I would do at least 2800 in a quality 9.5" converter. I know that sounds like a lot but it will drive just fine. Ideas about vast amounts of heat buildup are grossly outdated. Most of the stock cam bolton cars go 32-3600 even.
Personally I use Edge they are a little more budget friendly, if you have the coin I would look at Yank, Vigilante is certainly good too.
Back when I was putting 20K miles a year on my car I had a ZZ4 cam208/221 .474/.510 112, with 2800 stall Edge and 3.42 gears some cheap 28" slicks and in very good weather it ran 13.2 at I think about 103mph Been a LONG time since that setup was in the car.
Old Jun 16, 2012 | 08:18 AM
  #35
williepgee's Avatar
i will make this my next upgrade. i have a good feeling that my tune is the biggest problem that i have though. i think something has got my timing full time retard. of course im not a genious either. but i know what my ls1 ram air felt like with just a couple boltons and this car isnt lifting the nose like it did.
Old Jun 16, 2012 | 09:35 AM
  #36
Was the knock sensor programmed out?
If it is functional in the pcm reconnect it and see what happens.
Old Jun 16, 2012 | 09:51 AM
  #37
My mods are LT pacesetters. Hotcam. Comp cam 1.6 rtr. Comp valve springs. 373 gear. Cai. Pcm for less tune. Egr delete. Throttle body bypass. Knock sensor unhooked. Street tires. My car is running 14 seconds flat. It ran 14.3 before all these mods. Runs smooth just no power. No one knows why.
Originally Posted by 96capricemgr
You could have installed something wrong or damaged something.
The tune could be complete crap I know I had some REALLY bad tunes from Bryan.
By knock sensor unplugged do you literally mean just unplugged or was it tuned out as well? I suspect leaving it disconnected but turned on in the programming could cause a full time timing retard.
As Dwayne has already pointed out, if all you did was unhook the knock sensor, and did not have it programmed out, you are seeing up to 15* of knock retard. The exact number is variable, based on engine operating conditions, but unless you had it tuned out, or unless the maximum allowable knock retard has been reduced significantly in the program, it is hurting performance.
You seem to be avoiding answering his question.
Old Jun 16, 2012 | 10:30 AM
  #38
williepgee's Avatar
I don't think that it was tuned out. We just unhooked the knock sensor the day before yesterday. Ran the same as it did hooked up the day before. I haven't got to talk with them at pcmforless yet though.I do know that my engine is a little more clattery with this new cam and rockers. So it could very well be the knock sensor I hope
Old Jun 16, 2012 | 11:35 AM
  #39
Always good to have all the information.
You may have a case where with the knock sensor installed and connected, it is picking up false knock from the rockers = retarded timing, and with the knock sensor unhooked the PCM is retarding the timing due to the resulting code. That would explain why is doesn't run strong either way.
Old Jun 16, 2012 | 11:37 AM
  #40
dzltek's Avatar
I ran 14.3 with my stock m6 at almost 98. I was on street tires, granny shifting. I absolutely had no mods unless you count a muffler. So you have something definitely wrong.
Old Jun 16, 2012 | 11:43 AM
  #41
williepgee's Avatar
So next step will be contacting pcmforless and working out all the loose kinks. Thanks for your guys help. I will post the results ASAP.
Old Jun 16, 2012 | 01:28 PM
  #42
At this point I see no reason to contact pcmforless.
Resolve the knock sensor thing and give it a stall and see what it does then.
Old Jun 16, 2012 | 04:56 PM
  #43
williepgee's Avatar
How do I resolve knock sensor problem. I thought the tune had to delete it off computer
Old Jun 16, 2012 | 08:47 PM
  #44
Do you know if the knock sensor was already deleted in the tune? Did you check that box when you filled out the tuner's questionairre for the tune? Might want to check with the tuner.
Old Jun 16, 2012 | 10:09 PM
  #45
williepgee's Avatar
I don't recall seeing the knock sensor box on the questionaire. But I also didn't see the Maf descreening box. I caught it when I saw the report. So I'm going to say that it wasn't deleted on tune
