most effective "budget" upgrade
You're not going to be able to get anything for these cars for less than $200. The first thing that you should do is a CAI (cold air intake) I noticed a difference the minute I put it on. Great first mod. I perfer the K&N. It's plastic and doesn't transfer the heat as bad as the metal ones.
IMO, about the best bang for the buck mod you can do for an otherwise stock 94Z is a cold air kit. A good one that most people like is the K&N FIPK. They can be bought for around $200. You can pick up a used one for typically around $125.
thats awesome, as long as thers a noticeable difference... I was thinking maybe the vinyl linked off this site would be cool... but eh, i figured thats a little "ricerish" I should worry about performance first eh?
It's not "ricerish" either
So long as you don't put like a "Supercharged" or "383 LT1" decal on the side of your stock Z28, I don't think I'd consider quality and classy vinyl graphics ricerish
I dont buy the CAI thing, on the dyno 3 hp was gained from a K&N, 4 from the SS one..... but then there was two stock Z's that put down more without a CAI.....
cut out was good for 8hp and 14ft lbs
So go with a cut out or cat back.
