Moroso 20185
Old Jun 15, 2008 | 09:00 PM
RallyBoy1's Avatar
Moroso 20185
Has anyone ever used the Moroso 20185 oil pan made specifically for lt1's? I am thinking of purchasing this pan for my 383. There are several members on this site that indicate that it is okay to use the stock pan on a stroker. I am not ruling the stock pan out but if it does not work to my liking then I would like to have another option and the moroso seems like a good one. I also noticed that this particular pan calls for Moroso's oil pump and pickup, which is 5/8ths instead of 3/4ths. Will this be an issue? How many of you are using the 5/8ths oil pump and pickup?
Old Jun 16, 2008 | 12:40 AM
The Engineer's Avatar
I have the pan and the matching HV oil-pump and pick-up. It is a good package for a stroker, however, the pan had two leaks (bad and missed welds). Check it with light-weight oil for leaks before you install it.
Also, you don't use the OEM windage tray with this pan (it has one built-in).
WD
Old Jun 16, 2008 | 07:13 AM
RallyBoy1's Avatar
Do I really need the HV oil pump?
Old Jun 16, 2008 | 06:10 PM
Possibly not, it depends on your engine build along with the tolerances.
However, you "do" need a pick-up that is positioned in the correct location in the custom pan to play with the pan baffles and partitions. Along with the relationship of the pick-up and pan botton (correct depth), which is very critical.
WD
Old Jun 16, 2008 | 08:03 PM
RallyBoy1's Avatar
Is there a big difference using the 5/8's versus the 3/4 pickup?
Koby
Jun 28, 2015 04:46 PM
thenewkid
Apr 12, 2015 07:42 PM
thenewkid
Nov 27, 2014 09:41 AM
Ryan94V6
V6 Tech
Sep 9, 2002 02:41 PM
