more weight loss help
Old Dec 18, 2003 | 12:10 AM
lt1camaroman93's Avatar
Here is what i have gotten rid of to lose weight on the car so far.. What else can i do. current race wieght with 15# nitrous tank is 3285.
spare
jack
front sway bar and all mounts
complete a/c system
Complete heating system
Accesory bracket
power stearing
back seats
front impact absorber.
Pro stars all the way around.
Old Dec 18, 2003 | 12:14 AM
96ta(nick)'s Avatar
hmmm mine weighs 3600 without the spare and jack and with a half a tank of gas, PLease tell me why i bought a fully loaded,leather interior,t-top car?
Old Dec 18, 2003 | 12:16 AM
meengreen 94z's Avatar
Tubular k-member, lightened flywheel, carbon fiber driveshaft, remove interior paneling, go on a diet
Old Dec 18, 2003 | 12:21 AM
KCFormula's Avatar
Take out your carpet and padding, rear bumper support, manual steering rack, shave the extra threads off all the bolts.
Old Dec 18, 2003 | 12:40 AM
can't lighten the flywheel.. its a flex plate and weight next to nothing as it is.
How would i go about removing the rear bumper support??
Tubular k-member, a-arms, and manual rack are possilbe for next year. Also maybe a set of hal's.. That should be close to another 75lbs
I do not want to strip the interior of the car.. right now it looks stock minous the back seats.. that way no-body really catches on how much weight has been pulled out.
Old Dec 18, 2003 | 12:50 AM
QCKZ28's Avatar
take the carpet padding out, it weighs quite a bit. you cant see that its gone. there is also some padding behind the door panels, under the top of the dash.
swap in some racing seats.
AIR/EGR/EVAP systems
remove the rear speakers. keep the fronts.
jesse
Old Dec 18, 2003 | 12:53 AM
I forgot i already took the pading under the dash out already. I think i will pull the padding under the carpet out. Maybe i can teach my fiance to drive the car.. she is 60lbs less than i am. Thanks for the help guys
Old Dec 18, 2003 | 01:04 AM
QCKZ28's Avatar
do you have skinnies up front?
FWIW my chrome 5 star 16" wheel/tire weigh 47lbs each
jesse
Old Dec 18, 2003 | 01:06 AM
15x10 in back 15x3.5 in front with a 165 street tire on them. When i switch to a front runner tire i will loose about 10lbs.. the street tires are heavy
Old Dec 18, 2003 | 01:08 AM
93formula's Avatar
convert to ls1
Old Dec 18, 2003 | 09:23 AM
wish i had the money to do that.. If i did i would
Old Dec 18, 2003 | 11:17 AM
WS Sick's Avatar
You could remove the passenger side airbag.
Old Dec 18, 2003 | 11:28 AM
teke184's Avatar
how bout the speakers and associated wiring?
do you have power windows? convert to manual and ditch the window motors.
how bout the window washer fluid tank?
ditch the fuel tank and install a cell?
chromoly lca and phb, or even aluminum...i think someone makes those.
Old Dec 18, 2003 | 11:33 AM
BradZ28's Avatar
Yeah the airbags could go. I can't beleive you live in IL and removed the heater. If the heater and AC are gone remove the blower motor and heater core. Do you drive it in winter?
Also I was thinking about converting to header mufflers (turndowns?) and removing my heavy Y-pipe/catback exaust and tips to save some weight.
Also empty glove compartments, don't put more than half a tank of gas, port the heads, don't use double diamond subframe connectors are some uncommon suggestions I guess.
Brad
Old Dec 18, 2003 | 11:34 AM
BradZ28's Avatar
Oh and how about a lightened battery. Thunder racing has 13lb batteries, or just relocate it but the wiring adds weight.
