More suggestions needed for rough idle.
Old Jan 28, 2003 | 08:24 AM
JAFO1994's Avatar
I have a slight problem with a rough idle while the car is in gear and warmed up. It's not a miss of any sort and everything else runs perfect. I've changed tranny mount, plugs, wires, cleaned the IAC, seafoamed, deleted the EGR and AIR, put my screen back in the MAF, checked PCV, motor mounts and the car still seems to jump around in gear a little. This may be in my head, but it seems to idle better in gear after I beat the snot out of it. Any ideas what to check next? TPS?
Old Jan 28, 2003 | 09:26 AM
1994TransAm's Avatar
yes, tps is a good probobility!!!!!
if that doesn't work...do the idle air fix?
Old Jan 28, 2003 | 10:21 AM
JAFO1994's Avatar
Not familiar with the 'idle air fix'. What exactly does it involve?
Old Jan 28, 2003 | 12:21 PM
n2ceptor's Avatar
checked fuel pressure????? How old is the opti???? Mine has 118,000 miles and its running alittle rough sometimes at idle...And I have changed out everthing else, dreading when I do have to change it..
93Z Will
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
cmdeshon
Dec 12, 2014 10:51 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
