More oil pan clearance. Drop K-member?
Old Jan 25, 2004 | 08:42 AM
DR.ZED's Avatar
I've got the oil pan dropped about half an inch. I need more to check the pump to pan clearance. I am prepared to drop the K-member, but a few things just don't jive in my head.
The car is supported on jacks on the subframes. If I place a jack under the k-member and then remove or loosen the 6 bolts, is the engine going to come down (after I remove the motor mount bolts), with the k-member, or stay in its location held by the tranny mount? Won't the engine drop with the K-member?
Also, with the front suspension unloaded, when I drop the K-member, won't the shocks pull themselves apart? Or will I have to remove the strut bolts under the hood?
How much room can I realistically get with any of these methods, to check the pump to pan clearance?
Thanks guys. Any help is most valuable.
Old Jan 25, 2004 | 10:59 AM
Camaro90RS's Avatar
I too am interested in this info. TTT
Old Jan 25, 2004 | 08:49 PM
OBE1 95Z28's Avatar
The K-Member supports the engine via the engine mounts. The tranny will not keep the engine in place! Also as you observed, the shocks/springs mount to your lower control arms, and the lower control arms mount to your K-member. I've read some have been successful place a jack under the tranny (just behind the oil pan) to hold the engine in place. Personally, I used an engine hoist to hold the engine in position when I dropped the K-member.
Old Jan 25, 2004 | 11:03 PM
InjectedSS's Avatar
Yea you can do it. All you gotta do is put a jack under the bellhousing for an M6, then jack up on the engine a little to take the weight off the motor mount bolts. Then remove the motor mount bolts, then remove the 6 kmember bolts and pull on it till it comes down as much as it will go.. I also found that by removing the rack and pinion it gave me more room also.. NO the shocks will not come apart, you will be fine.
Old Jan 25, 2004 | 11:26 PM
97 RedSS's Avatar
I made a post last week on how to do this..Youll have to search for it..maybe in the advanced forum..
I just did this last week and so far NO leak and my oil psi goes up till 6k :P
Cody
Old Jan 26, 2004 | 07:58 AM
Jesse_Boyer's Avatar
I had to do this as well. Procedure went as follows:
1. support motor and tranny with a tranny-jack (I supported on the bell-housing as well).
2. pull motor mount bolts
3. pull the two bolts that hold the rack in place.
4. Loosen 6 bolts that hold the k-member in place.
You should notice that the k-member isn't dropping very far, if any. It will be supported by the shocks and the rest of the suspension. Actually, I had to PULL the back of the k-member down to get enough clearence to get the pan out.
HectorM52
Jul 30, 2017 11:46 AM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Elcojoe
Nov 17, 2014 10:27 PM
