Monoblade tb, good, bad, ugly.... :shrug:
Old Apr 15, 2005 | 11:06 PM
93z383's Avatar
Lightbulb Monoblade tb, good, bad, ugly.... :shrug:
Just don't have enough info to make a decision...help.
Old Apr 17, 2005 | 08:42 AM
magnumv8's Avatar
Re: Monoblade tb, good, bad, ugly.... :shrug:
depends on the engine if you really need it or not. A few things to consider:
You have to port out your intake manifold to the oval shape of the TB opening. They cost more than a 52 or 58. Are you running NA or boosted? If you are running NA you probably dont need the monoblade. If you are running a lot of boost, than it may benefit you.
If you determine that you NEED the monoblade, than go for it. AS&M makes a quality product. I went with their 58mm for my 383 NA application
Old Apr 17, 2005 | 10:50 AM
I'd be careful with a monoblade on a high boost application. That long unsupported shaft isn't going to like being closed against full boost. The highest HP blown LT1 I've been involved with made 1,125HP using a 58mm BBK.
You will also eliiminate the factory intake manifold IAC path when you mill the divider out from between the two throttle bores.
Old Apr 17, 2005 | 11:20 AM
93z383's Avatar
Thumbs up Re: Monoblade tb, good, bad, ugly.... :shrug:
seems to be the feeling I get from most people, thanks. Is there a reason people choose the BBk over Holley? The price isn't that different and man the Holley looks good.
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Amshnock
14
Jan 18, 2015 11:47 AM
mattszm6
Dec 14, 2014 07:09 AM
Fbodfather
25
Jun 21, 2002 04:12 PM
