monoblade opening with a 58mm TB
Old Mar 3, 2004 | 07:07 AM
simple's Avatar
i'll be recieving a intake manifold here shortly that i'm gonna open up for a 58mm TB and was curious if i would run into any problems if i just went ahead and took out the center section all together, so the opening is like that needed for a monoblade TB but using a 58mm Holley?
just run a straight edge across the top and bottom openings of the 58mm gasket marks and cut straight across then smoothed it out!
i think it'd be ok, just want a lil assurance
its all about weight reduction
Old Mar 3, 2004 | 07:18 AM
teke184's Avatar
can't imagine it would hurt anything...it there anything along the back of the TB that "needs" to be covered? and make sure to cut the gasket too...so it doesn't break apart and go into the engine
truecontr3
Oct 11, 2015 09:30 AM
NewsBot
Sep 30, 2015 04:20 PM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
tommalcolm
Sep 11, 2015 03:39 PM
Toxintwins
Sep 11, 2015 11:13 AM
