Mods & 1/4 Estimate?
Old Apr 1, 2004 | 09:11 PM
  #16
99BlackTA's Avatar
Also I saw that the FIPK has that plate to block off the heat from the motor to make the filter stay away from the motor. What could I do to fab something up like that?
Old Apr 1, 2004 | 09:13 PM
  #17
Vendetta's Avatar
I personally would get rid of the G2 and do a different intake all together, an SLP if you like underhood bling, or a K&N or Moroso if you don't really care. However, my first mod on an automatic would definitely be a torque converter... go with one around a 2800-3200 RPM stall speed. After that go straight to exhaust, longtubes and catback if you really want power.
Old Apr 1, 2004 | 09:33 PM
  #18
99BlackTA's Avatar
Where can you get the underdrive pulley kit??
Old Apr 1, 2004 | 09:34 PM
  #19
Vendetta's Avatar
try www.thunderracing.com
you can get it pretty much anywhere that sells LT1 parts, but thunder has been very good to me and their customer service is excellent.
Old Apr 1, 2004 | 10:58 PM
  #20
stereomandan's Avatar
My list of best performance mods, in order:
1) Cold Air Induction (CAI)
2) Headers
3) Cat-back exhaust
4) 1.6 RR's and springs
5) Cam and timing chain
6) Mail order PCM tune
7) Gears
8) Ported heads
9) 52mm Throttle Body
Injectors, wires, plugs, pullies...
Best Handling Mods, In order:
1) Sub frame connectors
2) 35mm Front Sway Bar
3) Shocks
4) Larger rims and tires
Dan
Old Apr 1, 2004 | 11:01 PM
  #21
re1080's Avatar
i would do a custom tune from a place like pcmforless instead of doing the hypertech
Old Apr 1, 2004 | 11:27 PM
  #22
99BlackTA's Avatar
How is this for the underdrive pulley?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2471290368
Old Apr 1, 2004 | 11:38 PM
  #23
QCKZ28's Avatar
that ebay link is a "stack on" under drive pulley, they show minimal gains, dont bet on 10-15hp, a dyno test showed 0.7rwhp gain with a stack on UD pulley.
when i decided to buy an underdrive pulley, i looked around and the general concensus is that the ASP underdrive pulley is the best, it is not a stack on it replaces the stock pulley, the ASP pulley has 25% under drive. it is a little more expensive though, i picked mine up for $150 plus a $10 belt.
jesse
Old Apr 1, 2004 | 11:39 PM
  #24
Bersaglieri's Avatar
2) Headers
3) Cat-back exhaust
7) Gears
8) Ported heads
3) Shocks
Dan
This is a great list to follow, dont wast cash on things like pullies at the bottom of the list. Get SFC's or something.
-Dustin-
Old Apr 2, 2004 | 02:15 AM
  #25
Vendetta's Avatar
2) Headers
3) Cat-back exhaust
7) Gears
8) Ported heads
3) Shocks
Dan
I would put a stall in the top 3 if the car is an automatic...
Old Apr 2, 2004 | 07:53 AM
  #26
Good call. I forgot he is an Auto. If he's running 2.73's in the rear, then he would probably want to move the gears up on the list too.
Dan
Old Apr 2, 2004 | 08:45 AM
  #27
99BlackTA's Avatar
I'm trying to do the cheaper mods right now...
I still owe a TON of money for this car and all the money I loaned for the vette restoration.
Old Apr 2, 2004 | 09:09 AM
  #28
99BlackTA's Avatar
Anybody happen to know the part number for the hypertech thermostat for my 94?
Old Apr 2, 2004 | 10:22 AM
  #29
93Z286Speed's Avatar
Mods like plugs and wires arent really mods imo
just a simple tune up..
CAI + Catback were the first 2 things i did to my car..
Then headers
and then straight to heads/cam with some other small bolt on stuff here and there
the cheap mods usually net lower hp (pullies, T-stat, Plugs. Wires. Coil) They are cheap for a reason
Old Apr 2, 2004 | 11:43 AM
  #30
btchincamaro's Avatar
HYP-1008 in summit. Just got mine and put it in yesterday. You should have your fans set to turn on at a lower temp if your gonna do that though.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
HAWG
Sep 25, 2015 11:41 AM
leftclixLS3
Sep 17, 2015 03:12 PM
