Welding a motor mount, electrical damage?
Old Apr 2, 2004 | 11:06 AM
94Z28WP's Avatar
One of my motor mount brackets (the bracket bolted to the block) has a couple of cracks in it... I'd like to have it welded but I'm worried of possibly frying the computer or electronic equiptment... Any chance of hurting anything even if I disconnect the battery or unplug the PCM? Or am I being overly paranoid?
Old Apr 2, 2004 | 11:09 AM
RicocheT's Avatar
Def unplug your grounds like you said (i think you said that)
Why not buy another mount?
Old Apr 2, 2004 | 11:52 AM
zx1216's Avatar
make sure you put the ground for the welder near the spot you are welding on and then you shouldn't have any problems as the current will only travel from the electrode to the ground.
HectorM52
Jul 30, 2017 11:46 AM
rjc1629
Jan 27, 2015 10:46 AM
Jazsun
Dec 29, 2014 12:14 PM
