modify stock oil pan
Old Nov 19, 2011 | 12:08 PM
Camaro350z28's Avatar
Did a search, hard to weed through all the posts. Im just curious if anyone has modified the stock lt1 pan for more oil and also 3.725 stroke all in one post with some pics and maybe which tray they have used? i cant find anything
Old Nov 20, 2011 | 09:39 AM
Re: modify stock oil pan
Not sure I've seen anyone build an LT1 with a 3.725" stroke (380 @ 0.030" over??). We used the stock pan with a Callies 3.75" crank, and it took a few gentle taps with a rubber mallet - nothing you can even see. But the results will depend on the specific design of the crank. The fact you are using a bit less stroke will probably help.
The shop used the stock windage tray.
HectorM52
Jul 30, 2017 11:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Elcojoe
Nov 17, 2014 10:27 PM
