Mobil1.. anyone using 15W50??
Old May 9, 2004 | 01:22 PM
CoUnTryMuZiCZ28's Avatar
Question Mobil1.. anyone using 15W50??
just wondering.. how is it? what climate? Im in FL... would it be good for me??
Old May 9, 2004 | 06:13 PM
besz28's Avatar
that is what i use right now.they recommended it to me after my heads and cam install. iam also in florida.
Old May 9, 2004 | 07:06 PM
generic's Avatar
I also use it, im in ny, i drop to mostly 10w-30 for winters though....
Old May 9, 2004 | 07:14 PM
n2ceptor's Avatar
5w-30 winter 15w50 summer
works for me and no problems/leaks
Old May 9, 2004 | 07:42 PM
SStrokerAce's Avatar
I've found on the dyno that the lighter the oil the better. The good thing about Mobil1 is that even the 0W-30 offers more than enough protection. Stock GM bearing clearances call for 5w-30 for all conditions and a heavier oil doesn't actually help that since the worst conditions are during start up. A really good oil grade to look at it is the Mobil1 0W-40 if you are looking for something that holds up to more abuse.
Bret
Old May 9, 2004 | 08:12 PM
ABA383's Avatar
I agree with above...I've been using Mobil 1 5w-30 since 1995...15w-50 is pretty heavy...remember, your crank is sloshing through all that heavy oil and taking a few horses with it....
--Alan
Old May 9, 2004 | 08:36 PM
badblackta's Avatar
I use it in both of my higher mileage LT1s and no problems, I am also in Florida. I consider it cheap insurance.
Old May 9, 2004 | 08:51 PM
696redZ-28's Avatar
I've been using it for my 5 years in florida used a thinner up north for cold starts.
Old May 9, 2004 | 08:55 PM
teke184's Avatar
i put some in my 60k mile LT1 once....and i could hear a VERY noticable increase in engine noise on startup
i think it was too thick for the clearances...
i'll stick with 5w or 10w
Old May 10, 2004 | 05:52 AM
Patman's Avatar
Even in the summer, you're still better off running 0w40 M1 over the 15w50. If there is any question as to whether or not you're using the right oil, get a used oil analysis done at the end of your interval. This will tell you for sure if you've chosen the correct viscosity.
Old May 10, 2004 | 08:18 AM
Eliminator's Avatar
I always run 5w-30 for the few months that I get to drive it.
Old May 10, 2004 | 08:42 AM
BadBirdLT1's Avatar
I run three qts. of 15w50 and 3 qts. of 10w30 and my car runs great. Reall wanted 10w40 but walmart doesn't sell it anymore and for 18.99 a 5qt jug I'll mix.
Also my bottom end is obviously not stock and my bearing clearences arent the same as GMs and the engine shop told me 10w40 would be best for my car.
Old May 10, 2004 | 09:36 AM
Chris'SS #2152's Avatar
I use 15w50 after my rebuild...I was using Royal Purple 20w50 but really can't find it anywhere and I did use 10w40 dino oil for break in. With my high volume oil pump/ etc...everything runs just right.
Acct 23749
Oct 3, 2006 09:11 PM
MaxCamaroZ28
Jun 20, 2004 07:34 AM
Smokn '94 Z
May 31, 2004 01:53 AM
Laymaster
Nov 18, 2003 06:43 PM
WipeOutXXL
Jun 27, 2002 03:10 PM
