Got my car dyno'd
Old May 9, 2004 | 11:45 AM
Robert95z's Avatar
Got my car dyno'd
Gotta dissapointed in the HP but tell me what youg uys think
Old May 9, 2004 | 11:53 AM
stereomandan's Avatar
Those numbers are STD, not SAE. You need SAE numbers to compare to other dyno charts.
Was it hot and humid the day that you dynoed? If it was, that could hurt your numbers.
You can convert the numbers if you know what the temperature was, the humidity and the barometric pressure that day.
Either way, you were running pretty rich at about 12 a/f.
Dan
Old May 9, 2004 | 11:56 AM
Koby's Avatar
Those numbers don't look to bad. A stock Lt1 with an A4 will dyno around 240 to 250, so a 20 to 30 rwhp pickup is pretty good for your mods. Did you run on a wide band? I would think there could be more hp to pick up with another tune, just curious to see what your A/F is....
Old May 9, 2004 | 02:39 PM
Robert95z's Avatar
A/F was flat straigh 12.0 and 12.2
Im not sure what the numbers would be corrected, i didnt even think about asking about that
Old May 10, 2004 | 09:07 AM
IDOXLR8's Avatar
HP number don't mean anything. Seems like you are running good numbers from your setup.
Old May 10, 2004 | 09:19 AM
Heatmaker's Avatar
Advanced Member
Wow ROb...first your girl...and now your car...
Don't try and race any Civic's soon... you'll be dissapointed.
Old May 10, 2004 | 09:44 AM
CANTONRACER's Avatar
STD still uses conversion...it is not the run as is...it's numbers are different than SAE because of different variables. STD can still compare against someone else STD.
Edit - your #'s do look 20 rwhp down though.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
birdblack
Dec 30, 2014 06:59 PM
USAirman93
Nov 24, 2014 03:37 PM
97 RedSS
Jun 10, 2003 07:58 PM
Burn_Out
Aug 18, 2002 08:49 AM
