Miss under load - need some advice
Old Nov 11, 2012 | 08:46 PM
  #16
sabresfan's Avatar
Re: Miss under load - need some advice
the plugs shouldn't be fouled out because I just had them replaced and gapped properly less than a couple hundred miles ago. But I guess my wires are bad because I saw them arching, and its running like it did when they were fouled out
Old Nov 11, 2012 | 10:10 PM
  #17
sabresfan's Avatar
how bad is the code 18? to what extent do i have to go about fixing it? like what is that going to take?
ever since doing the headers ive had nothing but issues. deff was not worth it at this point.
how could i get the egr code cleared to get rid of the SES light?
Old Nov 11, 2012 | 11:24 PM
  #18
The code is telling you that one of the injector cricuits is faulty, but does not indicate which one. Most likely, an injector is not working. It's relatively easy to sort out. Key on, enigne off, check for 12V at the injector harness clip at each injector (clip off injector). Continuing with harness clip off injector, measure resistance across the two pins of the injector. Shoule be 12 - 15 ohms. If passes both these tests, with engine running, use a noid light to verify the PCM is supplying the ground required to fire the injector.
Plugs "foul" because they get soaked in gasoline and carbon up. Doesn't matter how old they are or when they were gapped, if it's been running rich enough.
Old Nov 12, 2012 | 01:32 PM
  #19
sabresfan's Avatar
thanks Injuneer I really appreciate the help and info. unfortunatley I'm away at school so I've got to wait until I come home for thanksgiving until I can sort through these issues.
I used to get close to 20 mpg city driving and now its barely geting 10 mpg so its really frustrating. and now i need to get new spark plug wires on top of whatever else i need to do...
Old Nov 13, 2012 | 11:39 AM
  #20
sabresfan's Avatar
any recommendations for good spark plug wires to use with headers??
Old Nov 14, 2012 | 07:08 AM
  #21
Guest47904's Avatar
Guest
I believe I have a full set of MSD wires. PM with your address and Ill ship them to you.
Old Nov 14, 2012 | 02:51 PM
  #22
sabresfan's Avatar
PM sent
Firechicken350
Jun 6, 2015 11:25 PM
MDZ28
Exhaust System
Apr 29, 2015 07:44 PM
edman
Mar 13, 2015 09:39 PM
captcorvette
Mar 7, 2015 12:37 PM
