miss after plug and wire change
my camaro has an intermittent miss at all rpms almost always when im on the gas sometimes itll miss sometimes it wont i changed my plugs and wires and no difference my car has 101k with the stock opti should i replace it? thx
o yea before and after the plug/wire change i got a random misfire code
Re: miss after plug and wire change
Check the cylinder mis-fire counters and see if any are misfiring consistantly. Then try the inductive timing light trick to see if you can pick up on the misfire visually. I personally don't like to throw parts at a problem without first testing the parts I want to replace.
If it turns out when you check the counters to be purely random (not usually) then the hard work begins.
armedtrigger
Feb 24, 2015 08:30 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
