mislodged pushrod
Old Mar 2, 2005 | 07:52 PM
JeremyZ28's Avatar
mislodged pushrod
Had some noise coming from the engine, took off the valve cover and the one pushrod was mislodged from the roller rocker. I loosened the roller rocker and lodged the pushrod back in and tightened the rocker the same as I had used to loosen it. 3 days later the pushrod is mislodged again, what would cause this? A sticky valve?
Old Mar 3, 2005 | 12:30 AM
OBE1 95Z28's Avatar
Re: mislodged pushrod
The valve lash could have been set wrong when the RR's were installed or the RR locking nut could have been installed wrong and the nut backed off. You definitely want to reset the lash on that valve and not just tighten the nut down the same number on turns it took to remove it. I'd reset the lash on all the valves...if one is worng, do you have confidence in the rest of them?
Old Mar 3, 2005 | 04:51 AM
sssalah's Avatar
After setting the lash properly try to rotate the rocker and see if the pushrod moves. Maybe the guides on your self aligning rockers are bad. It could also be from bad lifter.
Old Mar 3, 2005 | 06:06 AM
97WS6SCharged's Avatar
Is the pushrod still straight?
Old Mar 3, 2005 | 04:41 PM
JeremyZ28's Avatar
the pushrod isn't broken or bent. This lash you mentioned, where is it and where can I find some info on checking it
Old Mar 3, 2005 | 05:42 PM
joeSS97's Avatar
Alright,you are kind of new here.You want to adjust the rocker when it isnt being lifted by the cam.You are going to have to turn the motor over with a ratchet on the crank pullley.Watch that pushrod rise,then fall.When it is down all the way,tighten the rocker nut til you have no play between the pushrod and rocker.Then tighten it 1/2 turn more.This is the preload.....Do that to all of them.Hope you understand it...Shoebox has it on his site...A lot of info there.It could be a lifter problem.
Old Mar 5, 2005 | 05:21 PM
JeremyZ28's Avatar
did what u guys said, ran good for about two days and the pushrod is mislodged once again. Something else is wrong.......
13qtr
Oct 28, 2016 08:11 PM
Quickss96
Jan 29, 2016 05:56 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
94Form
Jul 17, 2015 10:56 PM
