misfire
Old Sep 19, 2010 | 11:24 AM
Bails098's Avatar
misfire
I have misfire i have dont the test on shbox for the opti and the number were within the 1-4 ac. Im not sure about my injectors or my wires what is the best way to test these and is there still a possibilty of my opti not working right... plugs were just done.
Old Sep 19, 2010 | 12:29 PM
moparman's Avatar
Before I started changing the opti, I'd check the wires. Since the plugs were just changed, there's a possibility a couple of the wires could be swapped and firing at the wrong time. Also, a wire could be burned or not all the way on the plug or opti. You could also wait until it's good and dark and see if you see any sparks flying around the plugs/wires or coil.
Old Sep 19, 2010 | 12:37 PM
Bails098's Avatar
is there a way to check the wires if they are working right. can i use multimeter on them, what setting and what numbers am i looking for?
Old Sep 19, 2010 | 03:55 PM
Have you scanned it for codes?
If you have a faulty injector or power wire to the injector, you will get DTC 18. You can verify power to the injectors by measuring the voltage between the pink wire in each connector and ground. Should be 12V. With the harness connectors off, measure the injector resistance across the two pins. Should be 12-15 ohms. To verify the PCM is providing the ground that fires the injector, you need to install a 'noid light, and watch it flash as the injector fires.
Was it misfiring BEFORE the plugs were done, or only after?
The plug wires will give you a light show in the dark if they are arcing - as noted in the post above. You have to visually check to insure you have the right wire running from the right terminal on the Opti to the right plug.
Old Sep 19, 2010 | 04:45 PM
Bails098's Avatar
i had a wire touching a header dont know for how long i taped it up and seems to be about the same is there a way to make sure that wire is the problem before replacing it?
Old Sep 19, 2010 | 06:17 PM
moparman's Avatar
That wire is your number 1 suspect.
Old Sep 19, 2010 | 10:07 PM
Electrical tape can not insulate 30,000 Volts.
Old Sep 20, 2010 | 09:37 PM
tnts94z's Avatar
injectors bad?
I have somewhat of same issue and was wondering about testing injectors as well. I did the test that for resistance and also checked out voltages at wiring harness and both seemed ok. Is there any way to test the injector itself other than for resistance? Or is it something that you must send off to a shop to do.
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
Schul365
Aug 22, 2015 10:00 AM
Girrrrl
Aug 20, 2015 09:26 AM
zajones
Jul 30, 2015 02:18 PM
