Mini Starter Question? Please Help
Old Sep 14, 2003 | 04:18 PM
EvlViln's Avatar
I have a 94 LT1 TransAm, I am contemplating a mini starter for a few reasons. But I have some questions.
1) Which company make the best/ most reliable one & Why (in your opinion)?
2) is there anything special that would need to be purchased with the mini starter to make it operate properly?
3) My compression is 11to1 will this limit my choices when buying a mini starter?
Thanks for any help in advance. Please keep in mind that price for this item is not a major concern of mine. Thanks again!
mine. THanks again!
Old Sep 14, 2003 | 04:23 PM
Wilson's Avatar
Talking
Why not just get an LT4 Starter? Jason Cromer sells brand new ones without core charge for like $145 or so. Its a direct fit and is a bit smaller then the old LT1 starter.
Old Sep 14, 2003 | 04:37 PM
EvlViln's Avatar
is it lighter than the LT1 starter? if so how much?
Old Sep 15, 2003 | 02:47 AM
EvlViln's Avatar
bump
Old Sep 15, 2003 | 09:05 AM
bad79z28's Avatar
I just installed a TCI 351106 on my Stepson's '94 Formula. It was like $170 from Summit. It was a bolt-on. The best part...it only weighs 6.5 pounds.(It's a permanent magnet starter.)
Kevin
Old Sep 15, 2003 | 04:00 PM
EvlViln's Avatar
great thanks for the info, I appreciate it. thanks.
Old Sep 15, 2003 | 06:00 PM
12SCNDZ's Avatar
I like my 8 way adjustable CVR, from Jegs.
Frank
Old Sep 15, 2003 | 06:28 PM
InjectedSS's Avatar
LIGHTER starters WTF??
you guys are HARDCORE racers
Old Sep 15, 2003 | 11:45 PM
EvlViln's Avatar
70 percent of the 4th gens weight is over the front tires, putting it on a diet helps return the ratio to a better ratio. Every ounce counts, less car to move from a stop, less car to turn at speed, less car to stop when braking, it all adds up to a better car, on the track or off it.
just my opinion
Old Sep 15, 2003 | 11:54 PM
KeVMaN's Avatar
just my opinion
Doing things like AC delete, relocating battery, Tubular suspension stuff (you can save a TON of weigh here if you get crazy) make a decent difference, but I don't see a couple pounds from a starter doing anything.... probably a bit more than hosing the dirt off your hood
Old Sep 16, 2003 | 11:48 PM
EvlViln's Avatar
Done that, and that, and that, and that..... After you lighten it up you want to keep going. Trust me.
warmeck
Feb 5, 2015 11:04 AM
jermaine_rashad
Advanced Tech
Jan 4, 2015 02:32 PM
Jeff1904
Jan 3, 2015 12:00 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
