mini Starter needed to get around LT headers
Old Jan 8, 2010 | 10:33 AM
2NASSTY's Avatar
What have you Guys used? I'm looking for a high torque gear reduction mini-starter that will clear my newly installed Quad-1 long tubes. I'm leaning towards this CSR unit.
http://www.summitracing.com/parts/CSI-100U/?rtype=10
Old Jan 8, 2010 | 10:49 AM
bowtiedad_z28's Avatar
Here is one from another site for sale. Price is good.
http://www.z28.com/forum/f-body-part...e-starter.html
Old Jan 8, 2010 | 11:19 AM
RamAir95TA's Avatar
Perhaps you saw it in your other post, but I'll post it here too in case others need some reference. For my build to clear my LPPs, I used a ProTorque (now Jegs brand) mini gear-reduction starter, part number 555-10001. It's adjustable, required no shimming, and has no problem cranking over my 12.5:1 compression 383. Cost me about $140 - very nice!
Old Jan 8, 2010 | 11:45 AM
2NASSTY's Avatar
RamAir95TA,
Thanks for your replies. This Jeg's starter was 2nd on my list, but you may have moved it up to the top. I was not aware that it was adjustable. That is a huge benefit. Also no shimming was needed. Very nice. Did you have use non-stock mounting bolts?
Thanks again
Old Jan 8, 2010 | 12:12 PM
RamAir95TA's Avatar
Originally Posted by 2NASSTY
RamAir95TA,
Thanks again
Longer bolts are included with the new starter to accompany the burly aluminum mounting flange.
I didn't need to shim mine, and I am using a B&M SFI 153 tooth flywheel.
Old Jan 8, 2010 | 01:36 PM
6SpdLT1Z's Avatar
Is it common to need a ministarter for LTs or is this a B-Body specific problem?
Old Jan 8, 2010 | 01:47 PM
RamAir95TA's Avatar
I only swapped mine out because I wanted a higher torque starter for my stroker. That, and my stock one was cracked.
Old Jan 8, 2010 | 03:06 PM
96capricemgr's Avatar
I don't have a problem, using a stock starter with 1 3/4" longtubes.
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
Jeff1904
Jan 3, 2015 12:00 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
