Might put nos (should i, can The motor handel it SAFELY)
Old 05-11-2004, 11:26 PM
formula king's Avatar
okay im thinking about putting a small shot on my car (50-75 NX) but i got a few ques...first of all my car has like 140k miles on it but it runs STONG with no problems leaks or anything (12.9@107)
SO i was wandering is it safe at all to put in a 50-75 shot/ also what should i do to be extra safe on the motor........im ganna only spray 3rd and up, car is fast as it is 1st and 2nd
formula king is offline
Old 05-11-2004, 11:44 PM
Xride's Avatar
read every thread in this forum
http://web.camaross.com/forums/forum...?s=&forumid=23
you are going to put NOS on, but you say NX, well what one?
a 50 shot will hardly be noticed on a LT1, people are spraying 150 with ease.
Get a wet kit, get a Digital 6 plus ignistion so you can retard the timeing, get a rpm activated switch, and a WOT switch, and the fuel pressure safety switch.
theres moer I'm missing though.
Good luck, look to spends 1000 to spray a good amount safely.
Xride is offline
Old 05-12-2004, 06:28 PM
i want NX but i heard that TNT is cheaper and as effective?
so a 75shot is safe for what i want
Old 05-12-2004, 06:50 PM
96capricemgr's Avatar
75 is safe but not really worth the trouble, one Impala guy is spraying as much as a 280 two stage shot on a stock bottom car has seen 200hp shots for literally years, 175-200hp shots are almost common over there. I know the Mallory ignition box is popular with those guys it does everything you need as far as window switches and rev limt timing retard.
96capricemgr is offline
Old 05-12-2004, 06:52 PM
blind527's Avatar
im buying a ZEX kit, it has the smart system, and activates at open throttle. ill be running a 100-150 shot, probably 100-125 i don't wanna over do it. what do you guys think of that?
blind527 is offline
Old 05-12-2004, 10:43 PM
how would a 74 shot be on my 4.11s/ how is the shifting like.....i plan only to spray 3rd and after, i figured 1st and 2nd is fast enough with those gears
Old 05-12-2004, 10:58 PM
Advanced Member
Heatmaker's Avatar
Nos is good... Just don't forget to double Clutch and granny shift like you should.....
But no really I had the ZEX kit... awsome...
Heatmaker is offline
Old 05-12-2004, 11:42 PM
Dave88LX's Avatar
I'm not sure how your engine will respond ton nos...you might want to try nitrous oxide instead.
Dave88LX is offline
DirtyDaveW
12-01-2016 05:37 PM
10-31-2016 11:09 AM
Feffman
10-09-2015 05:42 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
01-14-2015 02:18 AM
NewsBot
12-28-2014 06:20 PM
Quick Reply: Might put nos (should i, can The motor handel it SAFELY)
