Might put nos (should i, can The motor handel it SAFELY)
okay im thinking about putting a small shot on my car (50-75 NX) but i got a few ques...first of all my car has like 140k miles on it but it runs STONG with no problems leaks or anything (12.9@107)
SO i was wandering is it safe at all to put in a 50-75 shot/ also what should i do to be extra safe on the motor........im ganna only spray 3rd and up, car is fast as it is 1st and 2nd |
read every thread in this forum
http://web.camaross.com/forums/forum...?s=&forumid=23 you are going to put NOS on, but you say NX, well what one? a 50 shot will hardly be noticed on a LT1, people are spraying 150 with ease. Get a wet kit, get a Digital 6 plus ignistion so you can retard the timeing, get a rpm activated switch, and a WOT switch, and the fuel pressure safety switch. theres moer I'm missing though. Good luck, look to spends 1000 to spray a good amount safely. |
i want NX but i heard that TNT is cheaper and as effective?
so a 75shot is safe for what i want |
75 is safe but not really worth the trouble, one Impala guy is spraying as much as a 280 two stage shot on a stock bottom car has seen 200hp shots for literally years, 175-200hp shots are almost common over there. I know the Mallory ignition box is popular with those guys it does everything you need as far as window switches and rev limt timing retard.
im buying a ZEX kit, it has the smart system, and activates at open throttle. ill be running a 100-150 shot, probably 100-125 i don't wanna over do it. what do you guys think of that?
how would a 74 shot be on my 4.11s/ how is the shifting like.....i plan only to spray 3rd and after, i figured 1st and 2nd is fast enough with those gears
Nos is good... Just don't forget to double Clutch and granny shift like you should.....
But no really I had the ZEX kit... awsome...:) |
I'm not sure how your engine will respond ton nos...you might want to try nitrous oxide instead.
