This might be a dumb question
Old Mar 25, 2006 | 05:13 PM
Bandit95LT1's Avatar
do stock rockers ever need to be adjusted?
Old Mar 25, 2006 | 05:50 PM
GreenDemon's Avatar
Re: This might be a dumb question
Not unless they're making noise or you have reason to suspect they're misadjusted. Locknuts have been known to loosen up before but that's not very common on an engine that has thousands of miles on it w/ no valvetrain work.
Old Mar 25, 2006 | 09:57 PM
As an engine wears, adjustment will change slightly. Modern hydraulic lifters are mostly meant to be left alone. That's why the stock preload has such a wide variance. They can run at anything from a full turn to almost none and still function ok. Most motorheads are going to check them every once in a while.
ModdedNerd
Dec 25, 2014 05:51 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
donot_4get
Sep 14, 2002 08:03 AM
