Meziere WP Fuse Keeps blowing...
Old May 29, 2007 | 07:34 PM
Will84's Avatar
I've got a Meziere WP that's been on the car for a while... probably about 7 years. Recently I've started having trouble with the inline fuse popping. It doesn't do it every time, but I don't drive the car much either.
Is this a sign that my WP is going bad?
I noticed that around the vent hole it looks like it's been getting really hot.
Old May 29, 2007 | 08:23 PM
89TramsAmGTA's Avatar
I would give Meziere a call. IMHO the motor is going bad.
Old May 30, 2007 | 12:01 PM
Compstall's Avatar
Probably is going bad. The motor may be laboring too hard and overloading the circuit.
Old May 30, 2007 | 12:15 PM
2000GTP's Avatar
Probably wouldn't hurt to give all the wiring a quick run-over to make sure there are no obvious faults.
Old May 30, 2007 | 12:19 PM
LOW TRAC's Avatar
I don't know if that pump is similar to the CDI? (I cant even remember what I had anymore) but my impeller used to back off the drive axel and jam on the pump housing blowing the fuse all the time.
Old May 30, 2007 | 01:34 PM
Spitfire557's Avatar
If it's 7 years old, I would go ahead and replace it anyway. Not really worth the risk of having it die on you, when it only cost so little to replace.
Old May 30, 2007 | 03:35 PM
blown383's Avatar
I believe that Meizre will rebuild them for a modest cost.
-B
Old May 30, 2007 | 07:02 PM
Will84's Avatar
I already checked the wiring and everything looks good.
Actually, the fuse blew and the temp went all the way to 260* before I noticed it. Could I have messed anything up?... I pulled over right away.
I've never heard that Meziere would rebuild them... I'll look into that.
Old May 30, 2007 | 07:38 PM
2000GTP's Avatar
If you caught it immediately, chances are you should be okay. Next time around I would look into one of those alarm systems that triggers an audible device when the pump stops working.
Jeff1904
Jun 5, 2016 05:00 PM
RUENUF
Mar 13, 2016 03:37 PM
autoxr166
Sep 25, 2015 04:21 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
z28cam1993
Sep 9, 2015 04:08 AM
