Meziere water pump enough for street?
Old Mar 8, 2004 | 10:44 PM
chrism400's Avatar
Lightbulb Meziere water pump enough for street?
Is the 35 gpm pump enough to cool a 12 to 1 383 or do I need to spend the bucks on the 55 gal one?
Old Mar 9, 2004 | 01:23 AM
johnny o's Avatar
Just get the regular one. The HO one doesn't fit in 4th gen fbodys easily. A stock pump only puts out about 30 at about 6000 rpm so uhm, 35 at any rpm is good.
Old Mar 9, 2004 | 01:36 AM
Robbie's Avatar
My CSI has worked flawless since about a year or more ago. Just a few modifications to the housing of the stock pump with the dremel and it slid right in. Dont see why the Meziere would be much different. Plus taking the extra stress off the cam and gainging a few ponies is a plus. Kill 2 birds with 1 stone. Repair a busted WP and gain HP all in one
Old Mar 9, 2004 | 08:23 PM
arnie's Avatar
The oem pump is pumping appr. 80 gpm at 6000 rpm. This figure was an approximation supported/substantiated by SW.
Old Mar 9, 2004 | 08:53 PM
Jason Dove's Avatar
I've been running my Meziere for 3 years now, it's a good unit... just the regular one.
Old Mar 9, 2004 | 09:00 PM
ibanez6rg's Avatar
The elec. pumps flow more at idle than stock, not at 6,000rpm. But, you should be fine with it.
Old Mar 9, 2004 | 09:29 PM
Jon A's Avatar
arnie, could you be more specific on your source for that? SW?
Don't get me wrong, I believe it. I read the same thing here years ago when the Meziere first came out for these cars (somebody actually posted an SAE paper with info on the stock pump) but I can't find it anymore.
Thanks,
Old Mar 10, 2004 | 05:51 PM
arnie's Avatar
Don't get me wrong, I believe it....
No problem, Jon, I question some posts here, myself.
Stewart Warner message forum, not called S. Warner, but S. Components: http://www.stewartcomponents.com/html/forum/default.asp
Actual thread I found: http://www.stewartcomponents.com/htm....asp?m_id=1151
Old Mar 11, 2004 | 11:49 PM
Jon A's Avatar
Thanks.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
