Metallic Clicking or clacking noise
Old Jan 28, 2003 | 07:33 PM
chartscharts's Avatar
Hey there!
I have a '95 Z28 stock. Over the last couple of days (today's really bad) there's been a metallic clacking noise coming from the engine. It seems to be coming from the drivers side. It increases or decreases in frequency directly related to the RPMs (speeds up when the engine does, slows down when the engine does). There seems to be more of a hesitation in acceleration coming out of a stop but at higher speeds acceleration seems fine and power seems ok. Otherwise running ok.
But the noise is bothering me. CLACK-CLACK-CLACK-CLACK-CLACK
Old Jan 28, 2003 | 08:42 PM
pasmado15's Avatar
Secondary Air pump
there was a recall for some of us... my klaking noise was resolved after the recall was implemented.
n2ceptor's Avatar
What the temp like where you are at???? Could be that its cold outside and the oil hasnt reached operating temp... Or does it happen after warmed up, too???
93Z Will
Old Jan 28, 2003 | 08:44 PM
pasmado15's Avatar
You haven't run over any ducks lately---are you sure that noise was not the quacking from a duck?
Old Jan 28, 2003 | 09:14 PM
Negative on the ducks.
It happens after all warmed up and seems to be getting worse over the last day or so. It didn't use to do this.
Old Jan 28, 2003 | 09:26 PM
magius231's Avatar
sounds like an exhaust manifold leak to me...check around there and see if you notice any obvious blackened areas that it might be happening...you probably won't since you can't see most of it, but its worth checking (would also explain the hesitating)
Old Jan 28, 2003 | 09:54 PM
I'll look tomorrow. If it is an exhaust manifold leak, what would that entail to fix? Expensive?
Any other ideas of what that might be? Some sort of valve clacking or something?
Old Jan 29, 2003 | 08:04 PM
It would be a good idea to take off the valve cover and take a look. If you are getting a miss that corresponds to the noise, it could be valve train related. Possiblities might be bent pushrod, cracked rocker or spring, even something with a lifter.
If it is hard to isolate, let it idle with the cover off and use a long screwdriver or hammer handle and "lean" on the rockers one at a time to see if you can affect the noise. Hold the handle on the rocker so that it does not bounce. I hope you can understand what I mean.
Old Jan 29, 2003 | 08:55 PM
Bud M's Avatar
Make sure your spark plugs are tight.
Old Jan 29, 2003 | 09:48 PM
DeezT/A's Avatar
my car started to make the same nosie a week ago and it turns out that i bent two push rods, listen to shoebox he knows his sh*t. thats my .02cents
dolfan324
Jul 17, 2015 10:34 PM
Jul 17, 2015 02:47 PM
GT what?
Jul 14, 2015 10:17 PM
Jul 10, 2015 02:23 PM
colts0455
Jul 7, 2015 07:19 PM
