Metal in Oil!
Old Feb 16, 2006 | 10:26 AM
  #16
amean94ta's Avatar
Re: Metal in Oil!
Originally Posted by RCF925
You are going to have some glitter in the oil after a complete rebuild, Thats why I change my oil & filter 20 minutes after initial start up and tear open the filter to inspect, again after 100 miles and then after 500 miles. I had some glitter in my 385 rebuild but cleared up after the 500 mile oil change. As Loadre said I would have waited a while longer before tearing down unless you are hearing knocking or see chunks of metal.
agree 400 miles and i still get metal and assembly lube
Old Feb 16, 2006 | 11:36 AM
  #17
Tom Piper's Avatar
Re: Metal in Oil!
If you have the Extreme Duty Timing set from GM, check the water pump drive gear and where it mates to the back of the cam gear.
Tom Piper
Old Feb 16, 2006 | 03:47 PM
  #18
Evil Eric's Avatar
Re: Metal in Oil!
-Stock timing chain and gears - no damage there
-no damage on heads, springs, retainers. found today 2 totally fragged valve seals
-machine shop dissassembled block at no cost and said all bearings check out, no damage.
There was at least a full table spoon of metal in the bottom of the oil pan.Took a whole can of degreaser to clean all of it out..however the last oil fiter thant came off the motor had ALOT less metal in it than the first one to come off the motor. I guess I'll have everything cleaned, reassemble it and cross my fingers.
Edit: would the a GM Hot Cam tear up an oil pump drive? teethon it look really worn.
Old Feb 16, 2006 | 03:52 PM
  #19
blkchevyz's Avatar
Re: Metal in Oil!
did you clearence your oil pan?
Old Feb 16, 2006 | 05:26 PM
  #20
Evil Eric's Avatar
Re: Metal in Oil!
yes sir. its actually an odd setup..not a true stroker but a 355 w/ 6" rods and different style pistons than a stock lt1.
Old Feb 16, 2006 | 06:06 PM
  #21
LiENUS's Avatar
Re: Metal in Oil!
6" rod 355's arent that strange, its basicly a higher reving N/A 355. They make a good combo.
Old Feb 16, 2006 | 08:12 PM
  #22
Loadre's Avatar
Re: Metal in Oil!
Were they the oring type valve seal? When they go, they create a LOT of metal (both the actual spring on the oring and then the metal on the lower seal body)
Old Feb 17, 2006 | 08:36 PM
  #23
Evil Eric's Avatar
Re: Metal in Oil!
yes, that was the type of valve seal. since the machine shop said the block is in order im not going to reassemble it untill i clean the heads thoroughly.
Old Apr 8, 2007 | 06:15 PM
  #24
DR.ZED's Avatar
Okay, can somebody confirm glitter vs this.
Oil looks black after sitting, but if I drag my finger across the oil I can see fine grey streaks appear in the oil, like it was a dull grey oil slick.
Old Apr 8, 2007 | 09:47 PM
  #25
JP95ZM6's Avatar
Take a magnet to the glitter to see if it's steel/cast iron or not. More info always helps.
Old Apr 9, 2007 | 03:23 AM
  #26
Jason Dove's Avatar
Did you take a look at the Windage Tray? I had a buddy take metal off of his...
R@mpage
Apr 20, 2015 10:02 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
