Meann Knocks :(
Old Oct 30, 2011 | 09:41 PM
  #16
Re: Meann Knocks :(
Originally Posted by raroz28
Can you clarify the differences between the LT1 and a traditional SBC?
The main differences are the passages for the reverse flow cooling, including the way the water pump mounts.
Old Oct 30, 2011 | 09:45 PM
  #17
Re: Meann Knocks :(
Originally Posted by PaNaRaMuH
I didn't know it had holes in the oil pan until I got it up on Jacks today and took a look.
I'll try to find a 93-96 LT1 block just to make things really simple. I'm kinda pissed off because it's a shame this happened. The kid who owned it before me ran 90W Gear oil as his engine oil.
Also, a couple of the roller rockers I could literally pick up and move side to side, almost 75 degrees. It's Cylinder 3 & 5 on the right bank. Is this normal?
Not sure what you mean about the lifters, but sounds like everything below the heads could be totally trashed. You had to know it had some real problems when only paying $1000. If the PO used gear oil for motor oil, no telling what else is suspect.
Old Oct 30, 2011 | 09:46 PM
  #18
raroz28's Avatar
Re: Meann Knocks :(
No it's not normal at all. Pushrods could be bent, no way the car ran with the lash so far off.
Got any pics of the car and damage?
Old Oct 30, 2011 | 10:07 PM
  #19
PaNaRaMuH's Avatar
Re: Meann Knocks :(
I have pictures of the body of the car. Not the damage, though. When we get it in the garage tomorrow, I'll take a short video and upload it.
I'm hoping the cam is atleast still good. :/
Old Oct 30, 2011 | 10:23 PM
  #20
Re: Meann Knocks :(
Read this:
http://www.enginebuildermag.com/Arti...t1_engine.aspx
Old Oct 30, 2011 | 10:49 PM
  #21
dennis5374's Avatar
Re: Meann Knocks :(
Why not just purchase a new shortblock? Victory race engines, Golen engine's, or ellwein engines are all good choices and have packages priced from mild too wild. Good luck with the purchase, hopefully the drivetrain is unscathed "fingers crossed "
Old Oct 30, 2011 | 11:30 PM
  #22
vangill's Avatar
Re: Meann Knocks :(
Cams are not THAT expensive, esp compared to the rest of the build. at this point, id say plan on replacing everything.
94Maroz28
Oct 27, 2015 04:38 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
whitehooptie
Aug 10, 2015 07:02 AM
