which for me? Hotcam or EX224/230
Old Nov 20, 2003 | 11:11 AM
  #16
FuryZ28's Avatar
Can you break into the 11's w/ 370 rwhp...? Just curious. I haven't ran mine yet, but I've seen others with my setup, if not sometimes less than what I'm running and they're in the mid/high 11's...
Old Nov 20, 2003 | 11:20 AM
  #17
BradZ28's Avatar
Yeah there's guys who could go low 11's with 370rwhp. Those guys have an *** load of money into their suspensions, ET Streets, 12 bolt, Street Twin, probably weight around 3200lbs, and can drive really well.
I doubt I'll be there for a while but am hopeing for mid 12's @110+. That's a reasonable goal for myself. How much money you have to spend will determine your ET IMO.
Brad
Old Nov 20, 2003 | 02:31 PM
  #18
GREGG 97Z's Avatar
I would have been there recently with a harder launch and a little better 60' time and I'm not close to 370rwhp.
Old Nov 20, 2003 | 04:51 PM
  #19
Sanger's Avatar
Ok, it sounds like I'll be much better off then just going with the 224/230. Besides new lifters, timing chain and new springs to handle the lift, is there anything else I should get?
Old Nov 20, 2003 | 04:52 PM
  #20
Fastbird93's Avatar
Some 1.6 Rockers to take advantage of the lift.
Old Nov 20, 2003 | 04:58 PM
  #21
Sanger's Avatar
Will my GMPP 1.6's be fine?
Old Nov 20, 2003 | 05:02 PM
  #22
jkipp84's Avatar
I ran the 224/230 with the stock stall for a year. The only problem I had with it was a bit of creeping when stopped. Just had to press the brakes a little harder with the 850 rpm. Definitely install a cooler though.
As for driveability, it's fine. Couldn't be happier with the choice - plus there's still plenty left for when I get my heads done.
Old Nov 20, 2003 | 05:08 PM
  #23
Sanger's Avatar
That's a very good idea (tranny cooler) that I didn't think about. Cheap tranny insurance.
Old Nov 20, 2003 | 05:34 PM
  #24
S.J.S.'s Avatar
Originally posted by BradZ28
S.J.S.- The Hotcam is considerably smaller than the 224/230. (CC503). The 224/230 has more duration and alot more lift, .536/.544 actually. The Hotcam is 218/228 at .050 and maximum of .525/.525 lift, closer to the specs of the CC502.
Uh considerably......no I don't think so. You aint gonna feel any diff. One of my friends has the HC and the other has the 224/230 with almost the same mods. They run almost the same times except one has better hook. actually its the HC car. They sound the same also. Considerably.......Nah. Numbers wise, yes. Go check.....the are relatively the same.
Old Nov 20, 2003 | 09:01 PM
  #25
Chris 96 WS6's Avatar
A couple of things here....
That is not correct at all. If all you look at is the Duration at .050 lift, yes the XE grind is "bigger" but that does not tell the whole story.
If you look at advertised duration specs, which are taken typically at .006 lift..the hotcam has more duration. What this means is it will bleed off cylinder pressure more at lower rpms, which leads to less driveability. Total overlap will also be greater.
Yet this still does not tell the whole story. At .200 lift, the XE grind, thanks to its more agressive ramps, has quite a bit more duration than the Hotcam.
In a nutshell, the XE cam opens the valve later and closes it quicker, but it reaches peak lift faster and holds it near peak lift longer. What this does is give you the positive effects of a bigger cam w/o the driveability issues that go along with it. This is why I recommend the XE grind...you're going to get more power with the same or slightly better driveability than the Hotcam.
Comp's catalog has a section that lists all their lobe grinds, and gives advertised, .050 and .200 lift duration numbers. That way you can compare magnum cams like the cc305 to XE grinds, etc. VERY informative.
Old Nov 21, 2003 | 12:13 PM
  #26
Sanger's Avatar
So are my GM 1.6 rockers fine for what I'll need?
Old Nov 21, 2003 | 12:15 PM
  #27
Fastbird93's Avatar
Yes, they'll be fine.
Old Nov 21, 2003 | 11:26 PM
  #28
trax's Avatar
Just an FYI, 3 runs down the track was enough to blow my tranny (with less than 50K on it) with the 224/230. Unless you have a shift kit or some kind of buildup, you might want to be careful.
The T56 loooooves the cam
Old Nov 21, 2003 | 11:34 PM
  #29
Sanger's Avatar
How will a shift kit strengthen my tranny?
Old Nov 22, 2003 | 12:45 AM
  #30
viperkiller's Avatar
I'm running the XE 224/230 and I don't have any problems below 2500. Hell, I have problems with tirespin @ 1800rpm...but I'm also running 4.10s in my M6...
...but of course, like everyone else, I'm always wondering "what if I went a little bigger?" I'm really curious how a 230/236 drives now...blah.
just my 02
i'm running the 230 236 112. i would like a little lope at idle but the performance is great. reliable and good fuel mileage, but i dont know about emmisions we dont have them here.
until about 1500 its pretty bumpy, starts to smooth out and by the time its to 2000-2500 its pretty smooth. hopefully i'll have some times for it tonight
