mcleod master and slave part numbers for lt1!
Old Jul 17, 2007 | 02:52 PM
djk19's Avatar
Thumbs up mcleod master and slave part numbers for lt1!
Mcleod produces a superior Master AND slave cylinder made from billet aluminum by Wilwood. Not just the master but the slave too! I never knew this and I dont think a lot of people do. There isn't a picture of it anywehre online. they actually show the master cylinder for all the pictures I have been able to dig up about the slave they make. Talk about hidden!
139001 - Metal adjustable master cylinder with hardware for 93-02 F-body
139024 - Metal Slave cylinder for pull type clutches
I talked to Mcleod and found out that they actually do make a metal slave cylinder and I have never once seen a picture of the piece. They include the metal master cylinder with their clutch because it is absolutely necessary (had to drop $330 on one) But they also make a metal slave cylinder for about $250. Never knew they made this part too... Figured this was good info for all doing the t56 swap or replacing a stock p.o.s. gm plastic slave. I never heard anyone mention this option before and haven't found another post about it. This slave is probably a lot nicer then the gm plastic piece that leaks all too often. I am happy I had the money to buy the metal master, now when the slave goes I will know what to buy to have the matching set.
Old Jul 17, 2007 | 05:30 PM
P L E A S E...... repeat P L E A S E post on the correct forum. This has to be the 10th post of yours I've had to move. How could you possibly think a question about a clutch belongs on LT1/LT4 Engine Tech? What part of this do you not understand?
In fact, why move it when its easier to lock it.
parkers Z28
Mar 11, 2016 08:14 PM
FirebirdGT
Dec 13, 2014 10:25 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
