McCleod Clutch
Old Feb 15, 2003 | 03:30 PM
cformulaowens95's Avatar
McCleod Clutch
I've pretty much decided that i'm gonna with the McCleod Clutch now my question is I don't really have the money for aNew fly wheel also Tbyrne sells them seperated if you want ie; Disk, preasure plate, T.O. bearing and such without a new fly wheel (having the other resurfaced) will i still need the adjustable master cylinder? and how much is it if i do this may go outside my clutch budget...... so if that happens what kinda clutch do you all recommend? I've heard alot about Star spec clutches
Old Feb 15, 2003 | 07:18 PM
LVZ2881's Avatar
If it is just the regulare McLeod clutch than you shouldnt need it.
The adjustable master is usually for the McLeod Street Twin only.
I got my master for $150 ( it could have been $250) from Thunder if I remember correctly.
i would avoid a SPEC clutch if you can.
do a search for some of the negative stuff said about them.
Old Feb 15, 2003 | 07:27 PM
Josh'95Z28conv's Avatar
I love my spec!!!!!! I think some of the people that have problems with them, actually have other problems. Its a good clutch.
Old Feb 15, 2003 | 09:47 PM
Grease's Avatar
I have the McLeod dual performance clutch, which I believe is what you are talking about. You don't need to replace the flywheel, just have it resurfaced and you don't need a different slave cylinder, the stock one will work just fine.
Old Feb 15, 2003 | 09:57 PM
cool thanks guys Mcleod performance disk and preasure plate it is!
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
