This may be obvious but,
Old Feb 5, 2008 | 08:40 AM
G. McDonald's Avatar
Am I the only one that doesn't already do this routinely?
While reassembling the LT1 in my cold garage, I found that it was a pain to get the heads to go down over the alignment pins and was also having a bear of a time getting the header bolts to go in without running the risk of cross threading them in the head. After I heated up the heads with a small space heater (warm, not hot), they dropped right on. With the header (SLP stainless shorties), I put one bolt in then heated the header until it was warm with a heat gun - the other bolts went right in. No cussing.
I wouldn't have thought that heat expansion would be that much of an issue, but apparently it is. Happy wrenching.
Old Feb 5, 2008 | 09:25 AM
truedualws6's Avatar
I had the exact same experience with heads and SLP shortys about a month
ago. I did not heat anything up though, just carefully pushed the heads down
on the pins and snugged down the center bolts and carefully threaded the
breslins into the exhaust flanges.
Old Feb 5, 2008 | 01:12 PM
Dave1980's Avatar
I used to have the SLP shorty headers, you have to be careful when putting them on the heads, as things are tight.
Old Feb 5, 2008 | 02:37 PM
95z28man's Avatar
Yeah it sucks, I did my entire head/cam swap in a cold garage.
marlar98
Sep 12, 2018 07:18 AM
AviatorDave
Dec 19, 2016 06:35 PM
PopoFormula
Oct 12, 2015 04:19 PM
pepon214tx
Sep 20, 2015 04:48 PM
blaze309
Sep 8, 2015 05:27 PM
