May have overtorqued heads
Old Jun 26, 2011 | 07:26 PM
RallyBoy1's Avatar
Is 75 ft/lbs too much for the final torque of arp head bolts? I used the arp assembly lube and thread sealer. Also I got slightly out of sequence on the final torquing. I went from torquing bolt number 9 to bolt number 14, 11, 12, 13, then I realized that I had already torqued bolt fourteen and I forgot to torque number 10. So, I went back and torqued number 10 and finished the rest of the bolts in order. Bolts 10 and 14 are very close together. Anything to worry about?
Thanks,
Sean
Old Jun 27, 2011 | 07:59 AM
RamAir95TA's Avatar
Re: May have overtorqued heads
You'll be fine.
Old Jun 27, 2011 | 09:32 AM
SweetZRag's Avatar
I just did mine last week and ARP told me to use 70 ft-lbs. You should be fine with 75. I agree, don't worry about the mistake in the order. Shouldn't be a problem.
Old Jun 27, 2011 | 09:47 AM
wrd1972's Avatar
Just drive it. Your likely fine.
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
