Max safe RPM on stock bottom end, and LT4 question
Old Dec 27, 2009 | 11:44 PM
  #31
93camaroLT1's Avatar
Originally Posted by JAKEJR
You asked about the MAX SAFE RPM, right? So why re-invent the wheel?
GM set the REDLINE and the cut off is for those who choose to ignore or, in a rare case a runaway WOT engine.
If you REALLY want the Maximum SAFE rpm, stick to the factory redline. It's the RPM that GM, in their testing, shows to be the maximum SAFE rpm the engine should reach and still be SAFE. NOW, if you're determined to push the envelope, go for it.
Remember the line from Pulp Fiction when Travolta told Samuel L. Jackson that he was being pushed into the "RED" - implying he was about to BLOW? RED=Redline; RED=Danger.
Should you choose to ignore it, it's your call. I never do, but that's my call.
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!! Graduation Day Parade 20 May 2010!!!
Do you seriously type all of this up every time you post?
To answer the OP- if you have the $$ to rebuild/replace the bottom end, just spin it up. When it breaks, then to the batcave to rebuild it better.
Old Dec 29, 2009 | 02:48 PM
  #32
JAKEJR's Avatar
[QUOTE=93camaroLT1;6215796]Do you seriously type all of this up every time you post?/QUOTE]
Every single one on every Forum I visit, which now are over 8.
BTW, I just bought his FIRST PAIR of 2nd Lieutenant's bars; 22K GOLD!
I've got a Harvard Graduate too; wanna read about her, LOL?
Jake
Old Dec 29, 2009 | 04:31 PM
  #33
You do realize you could simply type it once in your signature, and save yourself a lot of work.
Old Dec 29, 2009 | 05:00 PM
  #34
Bersaglieri's Avatar
Don't you get it? It's West Point! Oh, and Harvard! You cant' just signature that kinda thing, it needs to be mindlessly inserted to every post for the world to know.
Jake, I'm glad your here to help, but that is one of the most annoying things see when I read posts. With all due respect brag about that stuff somewhere else. How would this forum look if everyone went ahead and typed junk at the bottom of each post like that.
-Dustin-
Federal Law Enforcement Training Center ROCKS!! VOTED BEST Federal training facility in the Southwest 2009!!!!! Graduation ceremony a couple times a week depending on your law enforcement agency!!!
Old Dec 29, 2009 | 07:04 PM
  #35
Z-RATED94's Avatar
Originally Posted by kgkern01
Well I've now got a custom cam spec'd that I am going to order that peaks 6300 and should make 400-410 rwhp with LE2 heads on a stock block, and should help build a little more compression for the E85 that I'm going to run, so that's what I'm going to go with.
Sounds like a nice set-up and I'm sure you'll be very happy with Lloyds work and advice. If it peaks at 6300 you will at least want the shift points a couple of hundred revs higher for the best performance. That is were I draw the line with a stock bottom end, about 65-6600 rpm. Mine peaks at 6k and likes 6400 shift points. The next cam will have a 6600 shift point and at that level I still think it will live for a while. JMO!!
Old Dec 29, 2009 | 09:26 PM
  #36
maybe2fast's Avatar
MADZ28 set mine at 6500
CC503 ect
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Killer94z
Jan 13, 2015 12:06 PM
Jazsun
Dec 29, 2014 12:14 PM
Hurin
Dec 13, 2014 07:38 PM
97 RedSS
Jun 10, 2003 07:58 PM
