Max lift when using the 1.6 RR's that come with the HOTcam kit?
Old Apr 30, 2005 | 12:20 PM
FastZinTennessee's Avatar
I'm in the process of getting some things sorted out for my new motor. I just dropped the block off at the machine shop yesterday, and among other things I'm planning on getting a custom cam ground for it. I want to re-use the 1.6 roller rockers that I already have from the HOTcam kit. Does anyone know what the maximum lift is on these things? I think I've heard somewhere they won't support as much lift as some of the other RR's. Any other limitations that I should know about?
Old Apr 30, 2005 | 12:49 PM
1racerdude's Avatar
Re: Max lift when using the 1.6 RR's that come with the HOTcam kit?
Lift= 1.6xcam lobe lift.+.050 added for safety before coil bind=total lift,and whatever your springs say for coil bind(1.100-1.082-1.150?)Subtract your total lift from your coil bind and see if there is enough space.
WildRidez
Jan 16, 2015 03:10 PM
T/A lt1
Oct 10, 2002 03:14 PM
T/A lt1
Sep 5, 2002 06:53 PM
T/A lt1
Aug 16, 2002 11:24 AM
T/A lt1
Aug 15, 2002 01:53 PM
