Max lift with 1.7 RRs?
Old Feb 18, 2008 | 12:02 PM
LSWHO's Avatar
Like it says. What is the max lift I could safely have with 1.7 rockers?
Old Feb 18, 2008 | 12:17 PM
Might want to mention what engine, whether its stock or modified.
Hard to understand why people refuse to add a meaningful signature.
Old Feb 18, 2008 | 12:18 PM
LSWHO's Avatar
Stock LT1 motor otherwise. Basically I want to know how big a cam I can put into the motor with 1.7s before the valve meets the piston.
Old Feb 18, 2008 | 12:29 PM
LSWHO's Avatar
Is .600 the highest for stock heads?
I was thinking the CC503 or LPE 211/219 with these rockers. The LPE is .595 on exhaust side with 1.7s.
Old Feb 18, 2008 | 12:54 PM
jerminator96's Avatar
I can't really help answer your question but maybe you could answer mine. What is your goal here?
If you are trying to make the most power out of a stock bottom end, stock heads/intake LT1 then I can understand that. But you are going to find that the gains from that cam swap will be minimal, compared to what you would gain from a set of ported heads and that cam.
Just my $.02, good luck.
Old Feb 18, 2008 | 12:59 PM
LSWHO's Avatar
Exactly.
I, for right now, only have plans for bolt ons. But, I know eventually I'll do a cam. But I do know that it'll be cam only when I do. I KNOW that you can use them with a cam only car, but I want to know how big a cam I can go when/if I do.
Old Feb 18, 2008 | 03:44 PM
Originally Posted by LSWHO
Exactly.
That's cool, cam and full bolt-ons. Any reason you're going for such a short duration? If you're going for as much power as you can make why don't you get something that will keep the valve open longer?
And what do you mean you "know" that you can use them with a cam only car? If you can use them at all then you can use them with a cammed motor, you just have to keep the lift low enough or duration short enough.
I still stand by my original thoughts. I think that after you do the full bolt-ons with the rockers, you are going to be really disappointed by the cam swap. You can lift the valves higher and open them up longer but if the ports won't flow you won't make any more power. Just save up $2000 and get an LE3 package. That will make a whole lot more power (like ~430rwhp) and it saves you the guess work of picking a cam.
Old Feb 18, 2008 | 11:13 PM
roadtrip120's Avatar
i ran .614 on a stock bottom end with 1.7rr, but after i pulled the le2 heads after 500 miles i had some contact btwn the piston and the valves.
From personal experiance, loose the 1.7 and go back to 1.6.
Old Feb 18, 2008 | 11:22 PM
What duration?
Please remember that you can have 3 inches of valve lift if the duration is short enough. (and you can figure out how to actuate the valve)
Old Feb 19, 2008 | 01:12 PM
Dave1980's Avatar
I dont understand the use of getting 1.7 rockers unless you already have the cam installed. It would just seem easier to get the cam with more lift, and not have to deal with more rocker ratio over the 1.6.
Old Feb 19, 2008 | 01:18 PM
hosspwr94's Avatar
not to mention the bind your putting on the springs especially if your using stock springs.
Old Feb 19, 2008 | 01:38 PM
96m6lt1's Avatar
to even consider 1.7s on a stock spring is a crazy idea! 1.6s are maximizing the stock spring hell the stock cam does not even like the stock springs it tolerates it.stock spring is rated at 85lbs mine checked out at 80-82 with 110,000 miles on them and 13 years old......
i have said for a long time STOCK valve springs should be removed and replaced for performance driving of our kind!
Old Feb 19, 2008 | 02:19 PM
LSWHO's Avatar
You don't understand? How about having more lift without having a cam? More power, still no cam install. Either way I'm upgrading it all, might as well do it for 1.7s. Same price.
Old Feb 19, 2008 | 02:20 PM
LSWHO's Avatar
I never said I'm using the stock springs.
Old Feb 19, 2008 | 02:31 PM
96m6lt1's Avatar
good point but i never saw where you DID NOT, have stock springs!
roadtrip
