Max lift with 1.7 RRs?
Old Feb 19, 2008 | 02:31 PM
  #16
Dave1980's Avatar
Originally Posted by LSWHO
You don't understand? How about having more lift without having a cam? More power, still no cam install. Either way I'm upgrading it all, might as well do it for 1.7s. Same price.
If you were leaving the cam alone, then I can see, but your not.
That is why I don't understand the logic in going with the 1.7's when you can just get the right cam to begin with. I would think it would add more unnecessary stress to the valvetrain the higher the ratio you go. It seems like your building the setup around the 1.7 rockers.
Old Feb 19, 2008 | 04:04 PM
  #17
hosspwr94's Avatar
either way 1.7's on an LT1 head are allot of stress on the valvtrain and I don't know how the factory head will do with 1.7's you might check on here to see if anyone else has even tried it. But hey someone has to be first right! good luck.
Old Feb 20, 2008 | 12:33 AM
  #18
LSWHO's Avatar
I am NOT doing a cam anytime soon. I AM building the valvetrain around 1.7s.
1.7s have been installed on LT1s before. The previous owner of MY LT1 motor had 1.7s on it.
This is not intended for anyone in particular and I don't mean to sound mean guys but PLEASE STOP TELLING ME WHAT NOT TO DO IN REGARDS TO MY SETUP. I KNOW WHAT IS REQUIRED FOR THE INSTALL. STOP ASSuming that since I haven't said exactly what I'm going to do that I'm not going to do it.
I simply wanted to know max lift before i run into a problem.
I'm going to keep it under .600 lift. /thread.
Old Feb 20, 2008 | 01:08 AM
  #19
Dave1980's Avatar
Ok I guess I just misread your posts. It seems as if you wanna know the what if factor (on 1.7's) even though your not camming it right now?
List your specs in a sig BTW ASSumer.
Old Feb 20, 2008 | 01:10 AM
  #20
LSWHO's Avatar
Yeah, I am GOING to do the 1.7s and I want to know for down the road (probably WAY down the road) what kind of cam I can do with the 1.7s without pistons touching valves.
Old Feb 20, 2008 | 01:14 AM
  #21
Dave1980's Avatar
Gotcha not really sure, but I am sure it is below .600 is safe.
Old Feb 20, 2008 | 02:57 PM
  #22
Iceman_19's Avatar
what is the stock cam lift?
Old Feb 20, 2008 | 02:58 PM
  #23
LSWHO's Avatar
.447 .459 with 1.5 Rockers.
Old Feb 20, 2008 | 08:04 PM
  #24
hosspwr94's Avatar
Depends on what year cam...
92 LT1 205/207 @ 0.050" .451"/.450" Lift, LSA 117
93-95 LT1 202/207 @ 0.050" .450"/.460" Lift, LSA 116
96 LT1 200/207 @ 0.050" .447"/.459" LSA 117
96 LT4 203/210 @ 0.050" .475"/.479" LSA 115
Old Feb 20, 2008 | 08:56 PM
  #25
1racerdude's Avatar
1.7's are no problem anytime.
If ya don't want the valves to hit- -clearance the piston valve reliefs now for your new cam,measure it and then you know what lobe lift ya can run with ANY ratio.
I run 1.8's with a .429 lobe lift=.772 lift.Not stock heads but stock can be used. Longer valves and bigger dia. springs to take the lift.
KYWes
Jun 14, 2022 06:52 AM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Cam's maro
Aug 11, 2015 07:45 AM
