Max Bolt On Rwhp???
Old Mar 8, 2005 | 10:53 PM
jaredwayt's Avatar
Max Bolt On Rwhp???
i did a search, but i really didint find what i was looking for.i was wondering what is the record, or what is possible for the highest bolt on rwhp possible with the supporting mods.???
-1.6 roller rockers(i consider them a bolt-on)
-kooks longtubes/ORY-pipe/cutout
-full msd ignition
-cnc'd intake manifold
-58mm or monoblade
-eletric water pump
-anything else im forgetting?
what do you think is possible on a dyno with a m6, 3.42 gear/10 bolt with a pulled belt.???thanks.
Old Mar 8, 2005 | 11:11 PM
Dave88LX's Avatar
Re: Max Bolt On Rwhp???
Just a side-note, the MSD ign won't give you any extra power...what's the goals with this car? Heads "bolt on" There is absolutely no reason to go with a 58mm or monoblade though at the power levels you're looking at. If you're looking for simple easy bolt-ons, you're on the right track, minus the TB. Put that into some gears and a shifter or something.
JMO.
Old Mar 8, 2005 | 11:14 PM
Kreinmc's Avatar
325rwhp is definately possible. I hit 313.66rwhp without all the boltons and running at about 12.4 a/f. With a pulley, tb, better tune and electric wp I am certain 325rwhp could have easily been had.
Old Mar 9, 2005 | 07:50 AM
jaredwayt's Avatar
i would also have the car dyno tuned, my goal for now is to have the highest bolton car rwhp.with a full suspension, a little weight reduction, a m6 with a 12 bolt and a 4.10 gear or better i want to be in the 11's pretty good.
Old Mar 9, 2005 | 08:38 AM
soontobeGN's Avatar
"Bolt-on" a supercharger and fuel system to support it, that should get ya the highest HP bolt on car...
Old Mar 9, 2005 | 08:44 AM
jaredwayt's Avatar
yea, if it was only considerd a ture bolt mon i would, lol.but i will upgrade my injectors and fuel pump regardless.
Old Mar 9, 2005 | 09:05 AM
Antz97ZNJ's Avatar
285-310...
Old Mar 9, 2005 | 09:24 AM
jaredwayt's Avatar
the car will be a low mileage pristine condition 1996 ss m6, the other day i read a 1996 firehawk do lie 278-280 to the wheels stock!granted this is abnormal but i want to be in the 330-340 range.i think sar2k put down numbers like that throuh his a4.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
TitoPR221
May 26, 2015 12:20 AM
QuickSilver02
Apr 7, 2015 11:12 AM
maybe2fast
Mar 16, 2015 09:45 AM
