matching jet hot long tubes to y pipe...
Old Jan 7, 2004 | 10:31 AM
30thannZ28's Avatar
Hey, I know I may be beating a dead horse here, but I couldn't get rock solid info from other threads. I just got my Jet Hot LT's in the mail and as I understand they are identical to the hooker lt's. I have yet to purchase my new y-pipe and cat back combo, but I need to know which y pipe fits either EXACTLY to the jet hots or gets REALLY close. I heard the mufflex one sucks and I should just get the hooker y-pipe, but I want more opinions first. I know I will probably get the hooker cat back and use the stock tips, but the stainless ones instead of the plastic.
Oh yeah, I have a 97 with no cats.
Old Jan 7, 2004 | 10:53 AM
doodad's Avatar
I got the mufflex ypipe and was pleased with the quality and the fit. The welds were good and the collector design was better than others that I saw. The fit needed a little coaxing on the driver side (dremel to grind a little of the crossbrace), but that was the headers fault not the y.
Old Jan 7, 2004 | 12:15 PM
aram's Avatar
My hooker y-pipe fit with a little massaging... I had to grind down my trans crosssmember and it sits really close on the driver side.. passenger side was no problem.. when I get a chance I am going to make some more room with a BFH. The only thing that kind of sucks is the crushed part right after the collector on the driver side doesn't seem optimal for flow. oh well.
Old Jan 7, 2004 | 02:19 PM
IslandZ's Avatar
If only someone would make an oval Y-pipe for our cars.
I have the Hooker Y-Pipe also and, mine is still banging on the driver side transbrace. I am installing Poly motor mounts this weekend so I will let you know it that give me a bit more clearance.
Be Carefull of the lost ground clearance!!!
I banged the flanged and developed a leak. It was a PITA to fix, and I had to use 2 flange gaskets and a ton of rtv, but it seemes ok now.
Old Jan 7, 2004 | 02:56 PM
ibanez6rg's Avatar
Get the Hooker, or better yet, custom.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
LT14LIFE
Feb 9, 2015 09:35 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
Jul 4, 2005 05:00 PM
