Massive wheel hop!!! HELP!
Old Nov 2, 2003 | 04:07 PM
  #16
xxsaint69x's Avatar
Originally posted by BBB
Once again: check your pinion angle. I have the exact drivetrain you do and when I first put it in I had huge wheel hop problems. I have a street twin, denny's 3.5 aluminum HD with 1350 yolks, Moser 12, BMR RLCAs set at the bottom hole. When I installed the 12 bolt it changed the pinion geometery. You have to get that cured before anything else will work. If that is perfect, then airbags are the next step.
BBB
i dont have any tools to check the angle, and i do not have 350 bucks for adjustable tq arm
Ill be gettin a airbag tomorrow (spliting it with my buddy ) What pressure should i run it at?
Marcin
Old Nov 2, 2003 | 04:47 PM
  #17
Got-LT1's Avatar
Marcin
Tha's a bit of a guessing game. I run mine around 30psi and have no problems. Some other guys I know use 35, 22, and 27psi. Just try between 20 and 35 until you find the best one.
Old Nov 2, 2003 | 05:01 PM
  #18
speedmiser's Avatar
I run my airbag between 10 and 15 psi.
Old Nov 2, 2003 | 07:00 PM
  #19
dist0rtion_69's Avatar
Unfortunately, I second the pinion angle. Its expensive, but my car was getting some serious wheel hop too.. One time it wheel hopped SO bad that it knocked the tranny out of 1st gear. I gave it a lil adjustment on the t/a and it isn't near as bad. It still has some, but I have LCA relocation brackets I haven't had welded on. Another issue I had with my car is if I don't grease the poly bushings every few weeks, it will start to gain a touch more wheelhop again, as well as get noisy. Keep those suckers greased or you'll have some bind.
Cheers,
jwade88
Jun 14, 2015 09:38 PM
CARiD
Feb 9, 2015 09:35 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
SAR2K
Sep 1, 2002 10:49 AM
wytblur
Aug 5, 2002 02:03 PM
