Mass Air vs. Speed Density
Old Oct 4, 2003 | 05:53 PM
kevmor99's Avatar
What kind of disadvantages would I have if I switched to speed density on my '95 LT1? (I see a lot of hot rods just put the air filter on the throttle body).
Old Oct 4, 2003 | 11:38 PM
kevmor99's Avatar
Anyone? Will the engine run a better A/F ratio w/ the mass air? Does it make a difference?
Old Oct 5, 2003 | 12:14 AM
Antz97ZNJ's Avatar
supposedlly maf react better to mods...ive seen all years run an 93-97 are all similar...no years run better then another 93-97 anyways
Old Oct 5, 2003 | 12:17 AM
kevmor99's Avatar
So later if I got the hotcam it would probably run better w/ the MAF?
Old Oct 5, 2003 | 12:46 AM
Buttercup's Avatar
If the tuning is correct it will run great in speed density. It can become time consuming getting those VE tables perfected though In some ways SD can give a person more control over the fueling parameters. My car runs better in SD than it did when I (stuipidly) ported my MAF. I have invested LOTS of time in tuning however.
While you can simply mount the air filter on the throttle body when running speed density it would still be preferable to run a "proper" induction. Hot air is not conducive to making power
DirtyDaveW
Dec 1, 2016 05:37 PM
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Fatdog2
Feb 13, 2015 08:19 PM
Jul 4, 2005 05:00 PM
