Mass air Senser
Old Jun 25, 2003 | 05:22 PM
Eliminator's Avatar
Mass air Senser
I just read in Car Craft mag. that if you remove the screen on your Mass air you get more horse power with no problems it was in this months mag. Anybody ever do this without no problems???
Old Jun 25, 2003 | 05:30 PM
Some do, some don't. Some run better, some worse. Don't damage it taking it out, so you can put it back in if needed. You might try a search, also.
Old Jun 25, 2003 | 05:50 PM
Eliminator's Avatar
I try doing a search and it doesnt work most of the time. I also just wanted to find out who did this mod. and if it worked. I need to learn how to adjust my firewall to let this in. Thanks for the info. Shoebox I tried to IM you it said you were offline.
Old Jun 25, 2003 | 06:17 PM
anaik's Avatar
Type in maf screen in the keyword and LT1 for the forum to be searched. There are 3 pages
Old Jun 25, 2003 | 06:54 PM
Sorry, I don't allow IM. It's too much trouble to maintain.
Old Jun 25, 2003 | 07:15 PM
Eliminator's Avatar
No problem, thanks for your help and your website rocks I printed every info. that was on it. I just want to know with this topic who descreened and no problems + what yr car they had. I turned my firewall off and read the MAF screen search and boy is that mixed reviews.
Old Jun 25, 2003 | 08:12 PM
Antz97ZNJ's Avatar
Its not worth it for the few hp you MIGHT pick up
Old Jun 25, 2003 | 08:53 PM
97FormulaWS-6's Avatar
it is mixed reviews.... some have had no problems, others have had problems... some say it's a good thing, others say it doesn;t matter...
Personally from an engineers standpoint it really depends...
the screen is used to straighten the airflow to allow the meter to correctly measure the flow going through it. In a typical CAI there is bends which effect the airflow and create turbulance... the only setup that I personally believe doesn't need the screen would be a WS-6/LS1 setup with a straight shot from the airbox through the MAF to the TB.
DirtyDaveW
Dec 1, 2016 05:37 PM
mightymouse383
Jul 20, 2016 07:34 AM
oldschool
Feb 9, 2016 09:21 PM
Fatdog2
Feb 13, 2015 08:19 PM
